my rehab 99 taco SAS
When and did a small easy shakedown run to see what needs to be done...wheel well up front needs chopping at firewall, 37s hit so 40s will kill it...
Definently need to remember to bring air chuck, I didn't air down ran 30psi....all terrains suck for that btw....
List front locker due to damaged air line...repaired it now but some of the stuff with 30psi and no front locker was a pia...
Here's a view of the pacific ocean...you could see Catalina if looking slightly north....
This is a rock line I'm putting together...need one big rock for driver side middle and it will be flop alley....
Then another line we goof off on...nothing hard or major bit a good place to find things that need work before hitting the big boy trails...
Made some sliders for the rear sides and will finish them up...don't like the single bar design so will beef it up...
Some burning out on sidewall...
OK maiden voyage is under its belt...went to johnson valley and ran chocolate thunder and sledgehammer at tinbenders....
Did amazing even with 37" bfg all terrains air down to 4 psi....
Built a skid system for the underside, rear cage for tire and c02 tank, and s.capped some 40" km2's ON....
#27
Thanks, and yeah it was a great time....next time hydro assist on 40s slightly tubbed....so next month....should prove to be a little easier....PS pump was going out and now with the bigger tires it needs to retire,...so new pump and ram set up next week....
#32
Did the trail gear tacoma 3.4 hydro assist with the 1650 pump...what a solid set up....with the 2" ram it moves em wherever I point EASILY.. having a pre made kit is defeknently nice...I sourced and did my last on and it was way easier to just order this time...
Sorry for the sideways pictures...tablet has major issues can get pics to email over to it....
#36
The u-joints are ridiculous lol....total beasts....the 30 spline outers and Rcv hub gear finished it off...
D60 front and 14 bolt rear linked is where its headed....chop 10" off frame shorten it down wheelbase and then coilobers (typo lol...coilovers) and bypass on all 4 corners...
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
