e brake cables too short after 63 in swap
i can get them hooked up but fully drooped they pull tight.i left them not hooked up for now.how can i extend them?this is a 94 runner w 3.0 and an auto trans.
thanks!
thanks!
You can loosen/relocate/eliminate clamps holding the cable as it runs along the frame back to the rear axle. On my '85, I relocated the front couple of cable clamps, I think the first one I just turned the clamp upside down so the mounting bolt was above instead of below the cable. The next one back I used a lower bolt hole on the frame and for the 3rd clamp, I eliminated that one and instead loosely tied the cable down onto one of the spring clamps to keep if from rubbing on anything. That and I also fashioned a riser for the axle end of the cable, not sure if that would work on the '94 axle/e-brake or not:
took a quick look yesterday and it looks like i might be able to get the driver side hooked up if i take all of the mounts off of it.i wonder if a driver side cable will work on the pass side too?that would prolly do it.
Johntom240
7
07-13-2015 12:18 AM
jon.r
07-11-2015 03:34 PM
