Does this RUF caster angle look right?
I am finishing up the details on my 4runner RUF swap, and I am a little concerned the caster angle isn't quite right...
Do I need to get some shims?
IF I were you I'd use string, a plumb bob, level, and calculator to figure it out. As 5-7 degrees is what I've read is perferred for large tires. I believe factory is 2-3 degrees. Been a long time since I was researching this subject. Pirate4x4 faqs has information on both. From the others I've seen looks like your front hanger needs to be dropped some.
If you have an angle finder, see below for a quick check:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
You typically want the front hanger dropped close to the amount the shackle is longer than stock. On mine, I run a +3.5" shackle and have the front hanger dropped 2.5".
if you decide to shim, you might want to check your draglink clearance from your leaf springs at full lock before to see how much you can shim without hitting
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 05:51 PM
Toys4parts
09-26-2015 01:56 PM
justdifferentials
09-05-2015 06:52 PM
