1999 SAS and Build-up
Old 09-14-2011, 04:01 PM
  #81
yotaman's Avatar
Originally Posted by akaphilly
done yet? did you use the TG or sky frame shackles for the front?
Not done. Just started working on it again. Been to hot for me the last couple months.
I'm using 5" tubs through the frame. It's hard to explain. I will get some pictures of it once I start working on the truck again.
Old 09-23-2011, 09:14 PM
  #82
yotaman's Avatar
Rear suspension done for now. Everything is just tacked on but it all looks good for now.
I'm using steel sleeves in the bushings so the hole was to big. Easy fix is to just weld new ones on. Ruff-Stuff had a sell on shock tabs.
Rear Shackles thought the frame with enforcement plates.
Shackle angle. Looks good for now. I plan to cut an inch of so out of the shackle and might also take one leaf out of the F150 pack. It has 4 leafs in it right now. All the weight is forward also. I think it'll end up around 35-40 degrees. It's right at around 20-25 now.
Old 09-24-2011, 06:20 PM
  #83
yotaman's Avatar
Worked on the POS today.
Took a leaf out of the F150 pack and now have a 25 degree angle. I'm planning on cutting the 6" shackle to about 4.5-5" that should be just right.
Worked on the front most of the damn day.
This is how I'm doing the shackle. Took forever to make sure everything was straight and square. The spacers are 3/8" think. I will weld them together to make it just one large spacer.
Old 09-26-2011, 04:00 PM
  #84
akaphilly's Avatar
very nice!!! now get some axles under there n show us ride height!! jk take your time man looks great.
Old 09-26-2011, 04:35 PM
  #85
yotaman's Avatar
Worked on the front some more today.
25 degree shackle angle. Still need cut down the leaf springs so I should somewhere around 35-40 after that.
Ended up moving 2 of the spacers on the other side.
Old 11-09-2011, 11:28 AM
  #86
Bawlzdeep's Avatar
Looking good so far man. Pretty unique approach. Any more updates? I'm looking forward to tackling my SAS in a couple months. Keep the Toyota porn rollin!
Old 02-08-2013, 06:46 PM
  #87
yotaman's Avatar
Finally got the fire again and started working on her again today. Had to dust off the cob webs and clean the garage a little. Plan is to at least have her drivable by the end of the month. Anyone wanna help get her back together?
Old 02-08-2013, 11:17 PM
  #88
VANCE164's Avatar
If I wasn't so far away I'd help ya!
Old 02-08-2013, 11:23 PM
  #89
yotaman's Avatar
I'm thinking about redoing the front spring hanger to lower her a little more.
Thinking of doing something like this. What do you gusy think?
Old 02-26-2013, 08:11 PM
  #90
Alex Robert Aceto's Avatar
lookin good! Ill be interested to see how the tires do, thinkin about the Irocs or those.
Old 02-27-2013, 04:17 PM
  #91
B-yodaful's Avatar
Sub'd
Old 02-27-2013, 05:59 PM
  #92
Dras16's Avatar
Glad to see you are getting back on it! Have you decided how you are going to run your rear shocks?
Old 06-10-2013, 08:52 PM
  #93
bmxjedi's Avatar
sub'd! my 97 runner SAS is in the near future
Old 06-15-2013, 06:14 AM
  #94
87blackbeauty's Avatar
I'll help you put it together! I need custom work experience.
ZGjethro
06-07-2017 11:04 PM
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
Project90
09-24-2015 11:40 PM
Flying91
09-10-2015 03:41 PM
Quick Reply: 1999 SAS and Build-up
