Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
Alignment in Kent Wa.
Old 08-29-2002, 04:01 PM
Baja-Billy's Avatar
I see a couple of you guys are in the Kent area of Seattle. I'm new to the South, and was just wondering if you have any suggestions for a good place to get my front end worked on. I'm pretty sure I have some worn out parts up there. It sounds like my center caps are rattling around when I go over bumps. But there tight. Not to good! But I've drove it pretty hard and never replaced anything up there just aligned it. I used to go to a place up in Everet, but that's just to far now. Any sugestions?
Old 08-29-2002, 08:48 PM
markshoreline's Avatar
Baja,
Where did you go in Everett? I'm in the North end of Seattle, and Kent is too far for me. Mark
Old 08-30-2002, 06:28 AM
Baja-Billy's Avatar
Well I think it was called tire and wheel factory. I know the phone number was 425-745-2707 though. I had a problem with my front end and Les Schwab couldn't get it alligned. I took it there and they had to put it on a frame bender and pull my right front A-arm forward. It cost me $180, but it drove straight.
Old 08-30-2002, 08:48 AM
Toddski's Avatar
Hey there Billy, long time no hear
Give Paul S a buzz. He is just East of Kent at the Les Schwab shop.
I'm sure he will hook you up.
You can check out his pickup, very nice rig he has
Old 08-30-2002, 09:15 AM
Baja-Billy's Avatar
Do you know what street it's on?
Old 08-30-2002, 05:32 PM
I am in Maple Valley, on your way to Black Diamond. We don't do frame work, just alignments.
Hope to go with everyone on the 7th as I am OFF!!!!!!!
Old 09-03-2002, 03:29 PM
Baja-Billy's Avatar
I hope I don't need frame work again! Do you replace front end part's at Les Schwab, or just allignment? (Not familiar with all the parts that go out in a front end. A-arm bushings, tie rods, ect.) Do you do it on the side too? I would like to get it done this week if possible.
Old 09-04-2002, 05:31 PM
We can check out the alignment and front end for free. You need to set up an appointment. We do replace front end parts also. I don't really do stuff on the side but am willing to help if possible.
Old 09-06-2002, 06:16 AM
Baja-Billy's Avatar
I tried calling the LS in Coventing (I think that's the one you work at Paul), but it was busy both times. So I called the one right down the street from my house in Kent, and set up an appointment for Saturday morning. Hopefully it's not going to cost too much.
Old 09-06-2002, 04:56 PM
I am up from the one in Covington. I am in Maple Valley. Let me know what they find out. I am off on Saturday but Correy is working and he is good.
Old 09-09-2002, 06:43 AM
Baja-Billy's Avatar
Boy-Oh-Boy! Kent Les Schwab came through big time this weekend. Upper and lower ball joints, pitman arm, idler arm (sp??),new rortors,and alignment. $933. And they did it in about 5 hours. All in one day. They had to run around to a couple different stores to get all the parts, but they got it done. They found that my brake pads and wheel bearings were all in good condition, but my rotors were worn down below speck, and warped. Now the thing stops on a dime, drives straight, I ahve an e-brake that works. It's like a new truck. Oh ya, the re-torqued all the bolts on my lift kit while they were down there. I know were I'll be going from now on. Thanks for your help Paul.
Bd.
Old 09-09-2002, 08:04 AM
I am glad everthing worked out and you rig is driving great
ladybugRC
458
08-21-2020 10:41 AM
justdifferentials
14
06-11-2017 08:36 PM
voiddweller
09-28-2015 11:21 PM
gyroscope7
09-21-2015 04:55 AM
gyroscope7
09-13-2015 05:15 AM
Quick Reply: Alignment in Kent Wa.
