| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
VSC or Atrac???
#2 (permalink) |
I'll give it a shot here, but I have a '05 Taco.
So VSC is activated when a lateral skid is detected. Trac is activated when the wheels spin. A-TRAC is for 4-Lo and does essentially the same thing as Trac, only it has the ability to split torque front to rear as well as side to side. Hopefully that's not too confusing and hopefully that's accurate.
__________________
Fires, Friends, and Books Decree Wisdom, Strength, and Controversy. To believe with certainty, one must begin doubting. |
#3 (permalink) |
By Trac, i assume you mean traction control? Is this applied to only the rear wheels? I guess i am a bit confused as to the difference between traction control and A-trac.
On a side note, when this system is engaging while in 4hi i can hear it working but no indicators on the dash. When its in 2hi and i spin the rear tires in mud or snow i hear it working as well as the slip indicator flashes. |
#4 (permalink) |
Trac is only applied to the rear wheels when you're in 2wd. If you're in 4wd then it is applied to all four. Trac essentially cuts the power available to a wheel that wants to freely slip and thus encourages the wheels with traction to move you forward. A-TRAC does the same thing but also can adjust how much torque to send to the front wheels. In some situations, such as climbing a ledge, it is helpful to have more torque and traction available at the front to start clawing your way up and over. This is also where it is nice to have a front locker, but lockers in the front mess with you ability to steer the vehicle and can break stuff.
__________________
#5 (permalink) |
Co-Founder/Administrator
Staff
Atrac works in 4low, and is often better than using the rear E locker.
Atrac is also for the front. Some good reading here, topic #2. http://www.yotatech.com/f135/fj-cruiser-facts-98707/
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#6 (permalink) |
Thanks guys.. i understand now.
On a side note my OME lift and ARB bar showed up today! Cant wait to tear into it....
#7 (permalink) |
Staff
Great!
They look killer on the FJs. Mine has the OME HD up front, and the MD back aft. ![]()
__________________
#8 (permalink) |
What size tires are those Corey, 285's? I started on the front last night after work. Got the old coils off the front and stopped since i hadn't picked up the spring compressor yet. Its the easiest lift i've ever installed.
I went with the OME HDs on front and back. I tow a 5200lb ski boat alot in the summer, hopefully the back wont ride too rough w/o the weight of the trailer attached. |
#9 (permalink) |
Staff
Yes, those are 285x70x17s.
I have the exact same tire sized at 265x70x17 mounted to the factory wheels. My plan was to run the smaller set during the winter ( I have always had two sets of tires) time, but I never got around to switching them. The HDs back aft should be fine for you. I may switch to HDs later, as I have a lot of stuff in the rear, but I have not sagged yet with the medium coils. ![]() The trick up front too is to make sure you have the strut holder facing up like a bowl. Many have put it on upside down, and they gain more height, but it is wrong. Be sure to share some pics when you get it done.
__________________
#10 (permalink) |
Trac will cut engine power along with applying certain brakes to gain traction. A-Trac (in 4Lo) does not reduce engine power, but does apply the appropriate brakes.
VSC has nothing to do with Trac and A-Trac. VSC is Vehicle Stability Control, but it still uses the brakes to control the yaw and pitch of the vehicle when it feels you are about to loose control. I hope that makes sense. DEWFPO |
| Tags |
| 2002, 2008, 4runner, atrac, cruiser, cruisers, fj, good, problems, purpose, stopped, tacomas, toyota, vsc, working |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS | clarky_007 | 03+ 4Runner/GX470, & 05+ Tacomas | 8 | 08-20-2008 09:39 PM |
| Atrac? | 99SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 10-01-2006 05:23 PM |
| VSC off, VSC Trac and CEL came on after putting in K & N Air Intake | HenrySacto | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 12-30-2005 02:16 PM |
| 04 4-runner Transmisssion VSC Trac VSC off lights | freemanc | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-10-2005 10:57 AM |
| Effect of ARB lockers on VSC/ATRAC? | MO-Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-08-2003 09:08 PM |
