93-98 T100s All T100 trucks
Thumbs down for Sway Away T-bars
Old 12-26-2011, 07:29 AM
FW-739's Avatar
I started a T100 build about 2 years ago, did a 2 inch body lift, Trail Master IFS lift, wheels and tires and so on. Before the Trail Master set-up I had ball joint spacers and Sway Away torsion bars for a mild lift , had them cranked up . The ride was very stiff , that when I decided to put the Trail Master lift in to get lift without having to crank the T bars for lift. I completed the lift back in may and after un cranking the Sway Away bars they still rode like crap. I have put the factory T bars back in and its much better. Had to put the front sway bar back on , that was the only good thing about the sway away T bars was there you didnt need the front sway bar.
Even after un cranking the Sway away torsion bars all the down, the ride was thumbs down.
Old 12-26-2011, 10:19 PM
noahrexion's Avatar
THanks for sharing.
Why do you "have" to run the front sway bar?
Old 12-26-2011, 11:20 PM
cr@ves4wheelin's Avatar
They probably would have ran smoother if you had more weight in the front.
Old 12-26-2011, 11:23 PM
Originally Posted by noahrexion
THanks for sharing.
I'm guessing since the Sway-A-Ways have a higher spring rate, he had less body roll than he now has with Stock Torsion Bars. So he put the Sway Bar back on.
Old 12-30-2011, 06:45 AM
FW-739's Avatar
Also with the lift and the body having a higher center of gravity there is more body roll in the truns, thats why I re-installed it .
Old 01-12-2012, 08:43 AM
FoCo_4_Low's Avatar
Well noah, I guess the answer to your question is that you don't have to use the front sway bar (actually the only sway bar T100s don't have a rear one). I had mine off for about a year, it helps your wheel travel off road, but makes the truck a little loose/unstable on pavement, especially at highway speeds. If your truck is just a trail rig then I would say doing away with the sway bar is not a bad idea, but if you use it as a daily driver at all then probably best to have it.
ladybugRC
458
08-21-2020 10:41 AM
JookUpVandetti
09-30-2015 08:58 AM
potatopants
09-15-2015 06:26 AM
carid
Vendor Advertising
09-10-2015 06:11 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Thumbs down for Sway Away T-bars
