| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Removing 97 T100 auto hubs
#2 (permalink) |
i usually give them a good wack with a brass hammer and they pop out
#3 (permalink) |
Spray LIBERAL AMOUNTS OF PB BLASTER.
Take 5lb hammer and gently wack your way around the outer hub. The cone washers should pop right out. I had to do a set on the side of route 70 2 weeks ago replacing an axle seal in a t800 kw roll off truck.
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#4 (permalink) |
I don't have a brass hammer were could i get one. What else could I use and should I be hitting between the stubs on the hub?
#5 (permalink) |
Here are a few techniques I have found that work:
- http://www.4crawler.com/4x4/CheapTri...eWasherRemoval And for a brass hammer, try a real tool store if you have one in your town or maybe a good hardware store.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#6 (permalink) |
I used an old aluminum tipped hammer i made in machine shop. I held it against each washed and beat it with another hammer. I beat the crap out of it and just when i was out of breath and about to quit the first one popped out.. The rest are easy after the first one.
#7 (permalink) |
I used a heavy brass punch and a regular 22oz framing hammer and that has worked great when ever I've needed to get them off. Just hit them firmly and they work out fine but if its the first time since new they might require some extra persuasion.
Any good hardware should have a brass hammer or punch set. If you have a Harbor freight there stuff would work just fine for this.
__________________
97 T-100 SR5 4x4 5spd Ext Cab 100k and counting Forest Green metallic Aisin Hubs |
#8 (permalink) |
Staff
And just so we set the record straight, you are not removing the hubs on your T100. You are removing the ADD drive flange.
Auto hubs ended in 1988, and ADD started in 1989
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#9 (permalink) |
Try a piece of wood and a regular heavy hammer.
__________________
96 White T100 4x4 Extracab, Lifted, locked, & 35s Currently out of service due to roll over. Pending body work, SAS and rollcage |
#10 (permalink) |
I just tapped on the outside rim of the flange with a regular hammer and after the first cone-washer pops out, the other come out a lot easier (just like Zuke79 said).
__________________
1997 Toyota T100 DX 4x4 Extended Cab 3.4 Automatic 70,000 miles Warn Premium Manual Hubs Stainless Onki Brush Guard Wildcat Flash Nerf Bars Herculiner Bed Liner 03 Tacoma Alloy Wheels Last edited by finder216; 10-11-2009 at 03:58 PM. |
