YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-27-2008, 05:57 PM   #1 (permalink)
Windshield wipers not working please help!
I have a 91 pick up and the windshield wipers aren't working. If I run a hot straight to the yellow wire or blue/black wire the motor will run the wipers. I checked the wiring with a meter and when the wiper motor is hooked up the wire shows zero volts (still the yellow wire which is 'high' I believe). With the motor unhooked it shows 12v. I also found the wire coming straight from the switch and tried jumping it to the motor but I ran into the same voltage dropping to zero problem when the load was applied. Thanks for anyone that can help!
91diesel is offline
Sponsored Links
To remove this ad, register today!
Old 05-28-2008, 07:45 PM   #2 (permalink)
BTT, can anybody help? It sucks having everything else work on the truck and not this.
91diesel is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
noisy windshield wipers Toys-R-Us Off Topic Talk 0 12-16-2006 05:44 AM
Non-freezing windshield wipers? dynamo 95.5-2004 Tacomas & 96-2002 4Runners 6 01-07-2005 01:59 PM
windshield wipers BigJohn 95.5-2004 Tacomas & 96-2002 4Runners 6 02-26-2004 08:21 AM
Replacement for windshield wipers. OneTrickToy 95.5-2004 Tacomas & 96-2002 4Runners 5 02-16-2004 08:53 AM
Windshield Wipers cjrl 95.5-2004 Tacomas & 96-2002 4Runners 5 01-24-2004 04:13 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
