Turn Signals short out rest of gauges
OK here is the deal. Turn on my truck everything works fine. As soon as i flip on the turn signal everything except the speedometer goes dead.
1987 22re pickup.
I've checked all the fuses. Unplugged and replugged the whole gauge panel.
Any ideas??
1987 22re pickup.
Any ideas??
Check the grounds, main cab ground is a screw into the sheet metal behind the driver's side kick panel. Might be your other devices are finding ground through the turn signals and when they are turned on they lose the ground, or vice versa. And don't just look at the screw and say it is OK. Actually remove all the wires, wire brush the ring terminals, make sure there is no paint under the screw, then reassemble. Also check the flasher relay, in panel near ground screw.
Sounds like a plan. Im in my dorm right now and my truck is about a half a mile walk. lol I'll check it and repost what I found out sometime later today.
Fixed! Took care of previous owners very bad wiring, generally cleaned up all the wiring in general and i must have accidentally fixed whatever was shorting out. I love it when a plan comes together!
the1998sr5
15
07-14-2020 08:35 PM
Jeffreynmandy
07-18-2015 08:26 AM
jon.r
07-11-2015 03:34 PM
Poncho0206
07-10-2015 06:21 PM
