Tail lights not getting full power
Ok so I build my flat bed and figured out my tail lights...well kinda. I have three tail lights on each side of the truck. 1 Turn 1 Stop 1 Tail. None of the lights are getting full power though. The bulbs are only half lit. Does any one know how to rewire this all or get full power to the lights. Any suggestion would help. Ill give anything a test.
Those are on different power circuits so it's unlikely that the power side is a problem. They all probably ground through the same wire to the same grounding point somewhere at the rear of the truck and a loose or corroded ground causes extra resistance and the problem you describe. The FSM for your vehicle should have a description of the grounding point and the color of the ground wires.
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
