General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
oem foglights anyone used these?
Old Feb 17, 2009 | 08:40 PM
y2kltdsport's Avatar
found these on ebay anyone know anything about them they look just like the oem "stanleys"http://cgi.ebay.com/ebaymotors/99-02...6028QQtcZphoto
Old Feb 17, 2009 | 09:00 PM
dropzone's Avatar
Fossilized
If they are anything like the stock foglights on my old '05 Tacoma TRD they would border on being worthless. I replaced mine with a set of PIAA 510's, they out out a much better beam pattern. Hella 500's are also a great choice IMO.
Old Feb 19, 2009 | 10:36 AM
Maine Runner's Avatar
Go with Hella Micro DE's.
They look like this:
I replaced my OEM's with them. Huge improvement.
Best price and service through YellowandBlue Lighting
These are true plug and play into the exisiting wiring. You just need to remove the existing bracket/light and replace.
Old Feb 19, 2009 | 10:53 AM
wolfpack10's Avatar
I was stuck between the "OEM" ones and the Hellas for about a month. I finally decided towards the brand name and ordered the Hellas last night from yellowandblue. I've read that the Hellas corrode easily, so if you go that route grab some silicone. That's what I'll do unless i'm feelin froggy and decide to make splashgards.
Old Feb 19, 2009 | 11:14 AM
okie81's Avatar
I'd go with the hella kit as well. Looks like those have an adjustment screw though, which the hella kit doesn't.
Old Feb 19, 2009 | 05:34 PM
wizzells's Avatar
My Hellas do have an adjustment screw. I got the kit through Yellow and Blue lighting on ebay.
Old Feb 19, 2009 | 05:42 PM
okie81's Avatar
You're right, I had to go look at mine. The adjustment looks different from the one above though...
Old May 13, 2009 | 07:33 PM
fireball's Avatar
Anyone have further experience with these Hella DEs? Just got my truck and must say the stock lighting pretty much sucks. I am hoping the previous owner put some POS bulbs in the headlights and some good quality bulbs will be a big improvement.
The OEM fog lights are pretty pathetic. Just trying to figure out if the $150 for the Hellas is money well spent.
TIA for any insight.
Old May 18, 2009 | 05:44 PM
wizzells's Avatar
I put the Hellas in and I think it's a huge improvement over just the stock headlights. It was well worth the $150 for me
Old May 19, 2009 | 03:51 AM
4x4mike's Avatar
Guest
My factory OEM lights are Mirco DE's. The aftermarket models of the DE are similar but the housings are a little longer. Nice thing about this is that you can mod it to HID. The HID bulb is too long to fit in the OEM one but will work in the ones from Yellow and Blue. I love my lights. When adjusted they throw out a lot of light right in front. The OP's link was to a cheaper version. A version of the Toyota/Hella lights are found on many cars including corvettes so you can find them. The bracket is harder to track down.
Old May 19, 2009 | 04:07 AM
hillbilly's Avatar
Word of caution. I've gone through two sets of Hella Micro DE's on my '01 and all but 1 of the 4 have failed because of moisture/corrosion. The corrosion was so bad in two of them it literally destroyed/ate most of the rear housing, even *after* I prep'd, painted, and sealed the interior of the new set before installing them.
Micro DE's blow!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
HiLuxer
Jan 6, 2016 11:34 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
AlexJet
Sep 14, 2015 09:00 AM
