General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Left parking Front parking light out Oh No!!
Old 12-18-2014, 01:02 PM
wyoming9's Avatar
Red face Left parking Front parking light out Oh No!!
Getting ready to leave work last night after a short 13 hours my left front parking light (marker light) Is not working.
I guess the first thing to do is change the light in case it no longer works.
That didn`t help now what??(upon testing the light works fine)
I am scared to drive it like this. I can`t afford any more tickets it looks bad to the neighbors. When they come put you in cuffs .
Upon really looking at this it is now colder out and it was quite easy to see where some ne`er-do-well did some electrical troubleshooting this to me should be punished by stoning right there with using Scotch -Lok connectors.
Idiots that poke test lights or meter probes through the insulation of any wires just a inch from a connector.
Of course with the holes in the insulation the winter mix got in there and corroded the wires right off.
Since I was tired and cranky I figure to pull it inside and fix it right. This weekend.
In all I spotted the problem right away just wanted to go through the normal course of events to rule out another spot or different problem
So if this is you poking holes be aware your only going to cause more problems unplug and test things at connectors.
If it is in between two most times damage to the harness is easy to see.
If just one person learns from this it is at start.
Old 12-18-2014, 06:12 PM
habanero's Avatar
Whew! Somehow I'm glad I'm not a guilty party! Glad you got it figured quick.
Old 12-19-2014, 01:20 PM
wyoming9's Avatar
Red face
It is a habit to look for those punctures just about every time that will be the cause of the problem.
All fixed for now but the alternator looked like it should be replaced the belt was a little worn.
Old 12-19-2014, 11:04 PM
Staff
Terrys87's Avatar
Not sure why these trucks wiring gets so butchered. I spend more time putting it back to the way Toyota had it. There are plenty of adapters that just plug and play for most accessories. That is a common wiring problem I see a lot of. Hopefully someone will learn from your problem and not do it in the future.
Old 12-20-2014, 02:35 PM
habanero's Avatar
Hahahaha, I'm never selling my truck- the new owner would be in such a TIZZY!
(but I still don't poke the insulation to test...)
Old 01-04-2015, 10:24 AM
Odin's Avatar
Hey buddy I got sum connectors for ya, what color ya fixn ta use?
They work good for bouts 6 months. You can get rid of the kar before that rite?
Apparently you've never had any 70's and under hot rods. There be some truly idiotic butchering going on in that arena too.
Old 01-04-2015, 10:46 AM
wyoming9's Avatar
Red face
That would depend on the slackers you hung around with.
In anycase Scotch lok connectors and wire nuts are my go to of Choice and of course Romex wire is great!!
The scary part some might think is serious !!
Old 01-04-2015, 12:25 PM
millball's Avatar
It'll be OK if you stick with the #10 romex.
Old 01-04-2015, 02:12 PM
wyoming9's Avatar
Red face
#8 works better that way you don`t waste cable ties because it stays put where you place it.
Old 01-04-2015, 05:06 PM
Odin's Avatar
Romex
Brilliant! You fellers musta stayed at a Holiday In.
I'm gunna save me so much money!
Old 01-05-2015, 01:53 PM
highonpottery's Avatar
romex...that's too fancy!
sometimes you use bailing wire and insulate it with duct tape
Old 01-05-2015, 02:55 PM
millball's Avatar
Thats only appropriate on Fords.
Old 01-06-2015, 10:38 AM
Odin's Avatar
Oh heyls naw, somebody jus spiked de mic!
It be gettn cereal up in herrr
Old 01-06-2015, 12:05 PM
wyoming9's Avatar
Red face
Fess up who has really ever seen wire tie bales out of a normal size baler .
Old 01-06-2015, 12:19 PM
millball's Avatar
I've seen plenty of them, both 2 wire and three wire.
Guy I went to high school withs' parents had an old IH McCormick Deering baler that would'nt die. It had a cracked block that put water into the oil, so you had to put fresh oil in it every time it was run.
His mom was the only one who could sucessfully adjust the tension and get the wire mechanism to tie off. They used it for many years, and I think they still have it out in the scrap corral. I bucked plenty hay that it baled.
Charecter1
11-06-2023 10:08 AM
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Left parking Front parking light out Oh No!!
