General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
HID Conversion Problem HELP!!!
Old 11-02-2012, 09:36 AM
4Crawler's Avatar
Likely it is the polarity of the headlight voltages. See what voltage the HID kit wants to see, likely it is +12 volts on the high beam pin and 0 volts on the common pin. Toyota uses 0 volts on the high beam pin and +12 volts on the common pin.
Old 11-02-2012, 10:29 AM
paukyducky's Avatar
Thanks for the quick reply, sorry for the stupid question, how do I see what the HID kit wants to see?
http://www.kensun.com/Kensun_instruc...s/image004.jpg
thats the kit and instructions that I got. And thats all they give pretty much.
I used the technique that you had on your website, and I definitely found that when using the multimeter negative on the common and positive on the high or low i find ~ -12 V
Old 11-02-2012, 10:33 AM
4Crawler's Avatar
Contact the mfg. tech support folks and see what they have to say. Might be an internal jumper or switch they have to change polarity on the inputs.
Q: Who can I contact for more assistance?
A: With Kensun HID lights, you are never alone. You can always contact us at customerservice@kensun.com or call us at 212-933-9119 for any issue with your new lights.
That confirms the polarity.
Old 11-02-2012, 10:45 AM
paukyducky's Avatar
Great thanks, I sent them an email but they only open Mon thru Thursday and with this hurricane I don't think I will get a quick response . Wanted to try to figure it out myself
I appreciate the help thanks!, I will post what happens on here for others.
coreyedwards7611
01-16-2016 06:38 PM
coleypull15
11-03-2015 07:41 AM
BeMiceElf
10-10-2015 09:40 PM
jaretstuff
08-04-2015 02:08 PM
Edionne13
07-09-2015 01:59 PM
Quick Reply: HID Conversion Problem HELP!!!
