ECU Clicking?
ECU Clicking?
I bought a 1994 Toyota pickup a while ago and this morning I stalled the motor leaving my driveway (brain fart). So I tried to start the engine again and got repeated clicking from the passenger side footwell and no start. It clicked for maybe five attempts and then fired up. Is this the result of a bad ECU? Any advice is very helpful. Thanks!
The starter relay is behind the passenger side kick panel.
If the starter contacts are bad.
The relay will click-click-click because the contacts at the solenoid haven't made contact.
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Will drop out (and click) with a bad AFM connection or signal.
Thanks for the input. I really appreciate it since I'm brand new to Toyotas and to pickups and I scoured the search functionality and didn't find an answer. So, starter relay contacts...can I tell by looking if it's faulty or should I use the old Multimeter to check resistance? If you guys can recommend a good repair manual I would appreciate it. It's a '94 4x4 Extra Cab with the 3VZE motor. Thanks!
http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Here's an online version of the fsm (field service manual) for a '93, but it will work for you as well.
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Rob
Rob
zombie_barbarossa
10-02-2015 10:54 PM
