Thread Tools | Search this Thread | Display Modes |
#1 (permalink) | |
camper shell interior light wiring question
Hi,
I would like to install a light (dome style) on the inside roof of my camper shell. I have one positive and one negative wire already inside the bed of the truck. My question is how do I wire in a switch to turn the light on and off. I want to run one light and a switch running from the light down to the rear of the bed by the tail gate for easy on and off. Could someone please explain how to do this or post a little diagram. I would appreciate it very much. TS
__________________
Toyota truck Quote:
| Sponsored Links |
#2 (permalink) |
Welcome. I have a 12 volt light in my cap. What I did was found a light that has a switch already in it and wired it into my parking lights. so in other words, I have to have my parking lights on for the light to work. I did this so that if I ever left the light on by accident, it wouldn't drain my battery because I would shut my parking lights off which would kill the cap light light. If you don't have a light like this, all you have to do is get a cheap on-off switch and wire it into either your positive or ground wire. you just need something to interupt hte circuit.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member. new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. |
#3 (permalink) |
Check this page out. It should help. They say 6 volt circuit at the top of the page but it doesn't matter. everything is the same for 12volt.
http://www.allaboutcircuits.com/vol_6/chpt_2/3.html
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member. new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. Last edited by Froggy93 : 05-04-2008 at 08:08 PM. |
#4 (permalink) |
In my daily driver, I added a pair of lights in the shell. Just wired 12 volts to one side of the switch, the other side of the switch to one side of the light and the other side of the light to the negative wire. Close switch, light turns on. I used a 1 watt LED lamp so the power drain is very low (0.08 amps).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
[/IMG]Simple circuit diagram, I hope you get the idea. <a href="http://s223.photobucket.com/albums/dd49/vambo213/?action=view¤t=May42008005.jpg" target="_blank"><img src="http://i223.photobucket.com/albums/dd49/vambo213/May42008005.jpg" border="0" alt="Simple Circuit"></a> http://i223.photobucket.com/albums/d...ay42008005.jpg
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs. Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit, Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap http://www.cardomain.com/ride/3171939 Last edited by phildelfino : 05-04-2008 at 08:41 PM. |
#6 (permalink) |
in my cousins ford courier, we grounded the light in the shell. Then we ran a + wire to switch in the bed, to the light. We also ran the + wire for the dome light in the cab (the connection to the light), and ran that back there as well. Presto! Open door, light on. Flip switch in bed, light on. Flip switch in cab, light on. We also used a low-draw LED because my cuz was worried about the power draw on the dome light circuit.
__________________
Daily Driver: 1982 Toyota Pickup Base 2WD 22R, TRD Cam,5-sp Manual, Toyota Truck Nation High Miler- 300k+ MPG: 25/32 Off-roader: 1990 Honda H3011SA Riding Lawnmower, 11hp OHV engine, Carlisle SNOW-HOG Tires MPG: 1 Day of "Wheeling" per gallon Come to the 2nd Annual Oregon Yotatech Meetup!
June 26-29, 2009: Browns Camp OHV Park http://www.yotatech.com/f5/oregon-yo.../#post50902592 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camper Shell | van7559 | Misc Stuff (Vehicle Related) | 5 | 11-19-2008 10:55 PM |
| How much is this camper shell worth? | the_supernerd | Buying & Selling Advice Forum | 15 | 03-07-2008 06:57 PM |
| camper shell? | hanksyota | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 04-20-2007 12:54 PM |
| Camper Shell | van7559 | Misc Stuff (Vehicle Related) | 0 | 08-05-2006 04:23 PM |
| Camper Shell ? | van7559 | 86-95 Trucks & 4Runners | 3 | 02-10-2006 11:28 AM |
