General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Blowing EFI fuze and hot EFI relay in engine fuze box
Old 05-30-2009, 12:39 AM
swapped89's Avatar
I was drivin down the road mindin my own buisness then. My truck dies. I creep over to the side of the road.
The Good-
It turns over no problem.
All the lights work.
Everything has good clean connections.
Radio works
Blows air through the vents
All fuzes in the Junction block #1 by the driver side kick panel are good.
The bad-
Blown EFI 15A fuze in engine bay fuze block (relay block #2)
Hot CMH relay (C in relay block #2) i replaced this with a new one and the new one also gets hot (when the key is left in the ON position). I also replaced the EFI relay (B in relay block #2)
The EFI fuze blows/pops the second the ignition is turned to the ON position(the position just before START when it starts crankin the motor)
When this fuze blows there is no spark i have a spark checker that goes in between the distributor and the spark plugs and there is just no spark when this fuze blows.
QUESTION
I figure there is a definate short somewhere just wondering if anyone has ever encountered something the same or similar to this. I have pulled the relay block up from the fender wall and removed the bottom to look for chaffed wires they all seem to be in good condition. My mechanic friend sais sometimes the solder on the connections by the ignition can get hot enough to melt and ground each other out. I am at a loss right now. And have gone through more fuzes than.....someone that goes through a lot of fuzes. i have tried everything from 15A up to 30A they all pop just the same the second the key is turned to the ON position.
Old 05-30-2009, 12:50 AM
scuba's Avatar
There's actually more then a few threads like this..
Some dealing with bad COR's..
Mine had to do with bad wiring inside the fuel tank (dont ask)
More common ones have to do with the 02 sensor wiring shorting out due to melting from heat from the transmission..
Use the advanced search feature and check in the 86-95 folder search quote "15A* EFI* fuse"
make sure to use the asterisk as it will search for 3letter words with them. Good luck.
Old 05-30-2009, 12:54 AM
swapped89's Avatar
i tried searchin but i'll look again
Old 05-30-2009, 01:07 AM
swapped89's Avatar
Thanks for the hint on better searching this topic. i read your old thread about the gas tank. no bueno. i think im gonna start with the o2 sensor and go fromm there thanks a bunch. sounds like there are many causes of this problem
Old 05-30-2009, 06:55 AM
scuba's Avatar
Yes there are many causes..
Oh, Theres no refrence to which engine were talking about !?
IMO it could be the COR
Look through This page, At the bottom of the next topic it says things about the Circuit Opening Relay.
It shows a diagram and how to test it..
Old 05-30-2009, 06:57 AM
scuba's Avatar
Oh, And dont put bigger fuses in, Thats a waiting to happen..
Old 05-30-2009, 07:44 AM
swapped89's Avatar
Its the 3.o its in my signature
Old 05-30-2009, 07:46 AM
scuba's Avatar
hhmm, I believe electronics are still mostly the same..
Old 05-30-2009, 08:18 AM
swapped89's Avatar
BAM problem found and solved. thanks for the hints on searchin SCUBA i got a serious problem with the o2 sensor wires so for now i just cut them wrapped them up in electrical tape and zip tied them away from anything. How will no o2 sensor affect its drivin abilities
Old 05-30-2009, 10:36 AM
86Toyrunna's Avatar
aww snaps .. haha i didnt even knowtice that when we were puttin ur cat on. iv never driven with one disconected.. i know its gonna throw a code and kick ur check engine light on.. hell that was probably the reason u havnt got it to pass at DEQ. have fun replacing that, lots of soaking with pb.. hopefully you wont break the bung loose like my brother did on his old yote lol
Old 05-30-2009, 11:01 AM
1989toy4wd's Avatar
All I know is, when my 02 sensor went out, it was backfire casserole, with a side of hesitation and no power!
Old 12-08-2013, 10:43 AM
Evizzy33's Avatar
O2 sensor
My EFI fuse keeps blowing as well and i believe that it is due to my O2 wire making contact but i do not know where the O2 sensor is exactly. Any diagrams?
Old 12-08-2013, 11:28 AM
Punchy's Avatar
O2 sensor is critical
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Blowing EFI fuze and hot EFI relay in engine fuze box
