Best H4 HID kit?
Best H4 HID kit?
I've searched hundreds of sites, and found a ton... But i want to know some people experiences with them, I already have a cheapie ebay hid kit What is the best brand, on about a $50 budget?
+1 to the above. Unless you're at least going to get ecode Hella housings your stock housings wont work (sealed) and the h4 china ebay bs lights suuuuuuuuuck..
Get some hella 500's or something..
Ive had my DDM kit 5000k kit for about a year now, 6 months in I had a ballast fail and they replaced it with any issues. But they werent easy to get ahold of.
I think it failed because I kept starting the truck with the light in the on/auto position . Which is bad for the ballasts. Ive gotten out of this habbit and still love the DDM kit.
Ive had ebay kits before on other vehicles and one lasted me 2 years one last 3 months...
wierd how this subject seems to be coming up a lot lately..found a butt load of threads on it
X3 on the getting a set of HID driving lights.
I currently have H4 HID's in my '81..I am converting them back to normal H4's.
Just throwing cheap HID's in H4 housings is a bad idea. the cut off sucks, pretty much is illegal on the road. The only real way to do it is to spend some coin and do a projector conversion...
I did the same conversion 2.5 years ago, here is what I ended up with:
i didn't think the glare was that bad..after driving it for a while and seeing other trucks with just the HID bulbs and not projectors it finally sunk in what a bad idea it was.
At this point they are aimed so far down that they are about worthless...
oh and your differential is on the wrong side in your avatar for a 2nd gen truck
HID replacing the H4's:
I knew I would be running into some clearance issues, HID bulb assembly needs a bit more room than the stand H4:
I had to move the battery over a little bit for bulb clearance:
to solve that I dug through my secret stash and found a battery mount I bought a couple of years ago
to solve clearance issues with the coolant overflow/washer reservoir I used 1/2" spacer made of CPVC and some junkyard screws :
here are some comparisons--
H4 Low beams:
H4 High beams:
HID's
low beams
High beams:
overall install time was not too bad, maybe two hours. I am really happy with the outcome.
Just need to align them
H4 Low beams:
H4 High beams:
HID's
low beams
High beams:
justdifferentials
Just Differentials
06-13-2022 07:40 PM
RyanJ989
11
04-07-2021 09:41 AM
clok
11-19-2015 01:09 PM
JookUpVandetti
09-17-2015 09:25 PM
