YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-20-2008, 04:33 PM   #1 (permalink)
Yopar's Avatar
ACC circuit Kaput
Ok, Here's the current status of the wiring work I've been doing. Putting a kill into the Circuit Open relay, and other work such as Aux fuse panel mounted behind the pass kick panel, with cont. + power for things such as inverter and CB.
The ACC circuit that runs the CIG is not working now, but it was. I must have shorted it while testing with my meter in the 'cont.' position? Who knows. All I know is that it WAS working,--providing power with the key in the ACC position,-- and now those R-G (red-green) wires (CIG and Radio) are not working with key in ACC.
I have removed the fuses from the driver side fuse panel and tested them, they are all fine. Which one is actually the CIG fuse? I don't know, nothing is labeled.
The L-R wire (blue/red) coming from the IGN switch (large 12g wire under steering wheel) IS working with ACC on, so I know the IGN switch is working. I could tap in here, but it's driving me crazy that my CIG and radio feeds aren't working now.
Any ideas? A different fuseable link?
__________________
'87 4runner: fresh 22RE .020, 261c, OME springs/shocks, SDORI, relaxed Ts, 4.88s, front Lockright, marlin 1200 clutch, 16" Tacos, 255/85 bighorns, LCE header, magnafloW
"The Federal Reserve pretends to fight inflation but actually creates it. Inflation is the most insidious tax of all." --- ABOLISH THE FED
Yopar is offline
Sponsored Links
To remove this ad, register today!
Old 05-20-2008, 06:09 PM   #2 (permalink)
4Crawler's Avatar
Upper middle one on my '85:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-20-2008, 06:46 PM   #3 (permalink)
Yopar's Avatar
Interesting, that's where there is a 90 degree fuse tap. Whoever had the truck before me put this tap in there and it goes go a wire on the brake light switch (bottom wire). Why would they need to send power there? Removing the tap and putting the fuse in correctly returns power to the CIG but not the radio circuit.
Looks like a cob job to be investigated...yuk.
__________________
Yopar is offline
Old 05-22-2008, 04:01 PM   #4 (permalink)
Yopar's Avatar
Figured it out. Whoever had it wanted the brake lights to be inoperable without the key on, so they powered them off the CIG ACC circuit. That's my best guess. So back to normal. Thanks 4Crawler for yet again your information and dedication to the Yota community.
__________________
Yopar is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ac fan/motor kaput sonofbuster 95.5-2004 Tacomas & 96-2002 4Runners 3 04-17-2007 05:41 PM
antenna went kaput! mastacox 95.5-2004 Tacomas & 96-2002 4Runners 16 03-08-2007 05:04 AM
Thorley kaput? Phssthpok 95.5-2004 Tacomas & 96-2002 4Runners 2 04-09-2005 09:45 PM
Engine is kaput Praufet 95.5-2004 Tacomas & 96-2002 4Runners 4 05-10-2004 11:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
