General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1986 pickup air won't blow
Old 06-12-2013, 08:31 PM
86yoterbug's Avatar
I having.problems outta my heater it doesn't have act just heat. Well when i turn the heater on nothing comes out at all any suggestions?
Old 06-12-2013, 10:37 PM
RAD4Runner's Avatar
Nothing comes out?
Nothing turns on?
Nothing makes a sound?
A problem well-stated is a problem half-solved
Here's the schematic.
Suggest you check the fuses and check for voltage at fuse and relay as shown in schematic. Fuse and relay are here:
Old 06-13-2013, 04:00 AM
86yoterbug's Avatar
Alright ill try that. An no there's no sounds no nothin lol. Its gets rough driving when its raining with no defrost.
Old 08-02-2013, 07:24 AM
old fart's Avatar
Could be the blower motor too, what the squirrel cage attaches to.
Old 08-04-2013, 08:27 PM
abeD85flatbed's Avatar
the resistor could be shot. generally you lose high or medium, but I suppose if it completely failed you wouldn't get a thing out of the system.
Old 08-04-2013, 08:49 PM
RAD4Runner's Avatar
Have you done tests / anything that are noted in schematic?
Re:Resistor
Old 08-05-2013, 04:32 AM
Hadmatt54's Avatar
If you look at the schematic that RAD4RUNNER attached, you will see that all of the switch positions have a common pivot point which is tied to ground.
When you turn the heater switch to LO, it provides a path to ground for the relay coil, which closes the relay contact. Current flows from the contact through the fuse to the motor, but the only path to ground for the motor is completely through the resistor. With all of the resistor in the circuit you have the lowest speed.
In M1 position the relay works the same as above and the path to ground for the motor is through M1 to ground which is 2/3 of the resistor, which is a higher speed than LO.
In M2 position again the relay works the same and the path to ground for the motor is through M2 position which is 1/3 of the resistor, which is a higher speed than M1.
On HI, relay works the same, the path to ground for the motor is through HI, which bypasses the resistor and of course with no resistor in the circuit you get the highest speed of all.
So, if the resistor was shot (open) and the rest of the circuit is ok you will get high speed only.
Old 01-01-2014, 05:44 PM
86yoterbug's Avatar
Sorry for the time here phone never notified me, but it was the relay. Thanks for y'alls help
1986 Reg Cab 5speed 22r 3" lift on 35x15.5 Super Swampers 1988 Ext Cab 22RE 5 speed
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 1986 pickup air won't blow
