YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area, & More Articles In The Wiki) > Off Road Enhancements
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Closed Thread
Thread Tools Search this Thread Display Modes
Old 01-02-2006, 02:52 PM   #1 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Downey Idler Arm Brace For 2nd Gen 4Runner/3rd Gen Truck
Downey Off Road's Idler Arm Brace
(#45493 for 93-95 or #45486 for 86-92)
7/18/2004
Mike (Cebby on the forums) shows you how he installed the idler arm brace to beef up his front end.
Tools Required:
Rubber Mallet
19 mm socket
1/2" socket
Ratchet
Large slotted screw driver
Torque wrench
This mod is so easy. Ranks right up there with changing your air filter in difficulty. You don't even need to take off a wheel, or jack the vehicle up.
Here's a schematic from Downey that shows the components of the idler arm assembly.
The idler arm is on the right side of your US spec vehicle in the wheel well toward the front. Turn your wheels hard right to give yourself a little room to work. Here's what a stock Toyota idler arm looks like.
The first step is to remove the cap off the top. I gave the cap a few glancing blows with a hard rubber mallet to loosen it up. I was then able to put the blade of the screwdriver under the edge of the cap and pry it off. It doesn't take much effort. The cap is not reused.
Remove the nut on top of the idler assembly. Use a 19 mm socket to remove the nut. Once you get it started, you can spin it off with your fingers pretty easily. Save this nut for reuse later.
Remove the plate washer under the nut. This washer took a little effort to get off. I got my screwdriver under it and gave it a couple of hits with my rubber mallet to free it. Be careful not to damage the plastic bushing under it.
The plate washer is not reused.
At this point you can fit the idler brace on the idler arm. It drops over the stud on top and over the arm. Replace the nut on top of the idler arm and torque to 58 ft.lbs.
Put the supplied bolts through the holes on the bracket under the arm. Use a washer on the head side and the nut side of the bolt.
I put the head side out on mine since it looked cleaner and didn't interfere with anything on the backside. My bolts did not just push through and required a shot with the rubber mallet to drive them home. I cranked these bolts down as hard as I could. In my opinion, this bracket won't do any good if the bracket is loose.
Disclaimer:
This write-up is for informational purposes only.
The author, Downey Off Road and Yotatech.com assumes no liability should you decide to modify your vehicle based on these instructions.
We are not responsible for any damage or harm to yourself or others as a result of this modification.
Any use of this information is at your own risk.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Sponsored Links
To remove this ad, register today!
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2nd Gen Idler Arm w/ Downey Brace hodgepodge79 Misc Stuff (Vehicle Related) 6 06-07-2007 08:23 AM
new Downey Idler Arm brace/gusset '86-'92 rocket Misc Stuff (Vehicle Related) 2 03-25-2007 06:56 AM
Dana Idler arm for 2nd Gen online? photomike72 95.5-2004 Tacomas & 96-2002 4Runners 17 10-08-2004 04:49 PM
Where to buy Downey Idler Brace 2nd Gen? ptg 95.5-2004 Tacomas & 96-2002 4Runners 5 09-01-2004 03:37 AM
Anybody got a pic of a Downey Idler Arm Brace installed? UKMyers Offroad Tech 7 06-12-2004 04:24 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
