Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
99 4runner Tailgate window wiring, need wire color and location
Old 01-09-2012, 06:31 AM
Ruadd's Avatar
Exclamation 99 4runner Tailgate window wiring, need wire color and location
I have a 99 4runner and I am looking to control the tailgate window via a viper 791xv alarm system. I know that the factory keyless entry system has a tailgate window down function. I am looking to make my viper alarm system do the same thing. Does anyone know where I would find that particular trigger wire, and what color it is? I'm thinking I will just use my channel 4 output off of my viper to control this function.
Old 01-10-2012, 07:09 AM
Ruadd's Avatar
3rd gen 4runner rear window wires
The tailgate window down wire is green with yellow stripe located in the drivers kick panel. It is a negative feed so you will need to configure your relay to transmit a negative signal. This is not the same wire that controls the automatic down, which is found with the factory keyless entry. To get the same result you will need to time the relay to stay closed for 5 seconds
Old 01-26-2012, 07:16 AM
93NMyota's Avatar
If you want to roll it up and down, my advise would be to use a sunroof module "directed 529t" and wire it directly at the motor for the window. I installed it this way on my 4runner and its a little more work but works properly and has been this way for 2 yrs. otherwise you can used the wire mentioned by Ruadd and program the system to stay latched for about 5 seconds
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
Paul S
06-20-2002 05:07 PM
Quick Reply: 99 4runner Tailgate window wiring, need wire color and location
