stainless steel strength ???
Are stainless steel bolts strong enough to hold my Turbo to the exhaust manifold ? I know they're no grade 8. this is a difficult size bolt, that is why I'm considering it.
why would you even need grade 8 bolts? its just a turbo, what makes you think that you even need grade 8?
Edit: you'd probably want the bolt to be the same material as what you're bolting to so it expands and contracts the same rate.
Look up Tacoma Screw. They Have all the hard to find sizes and pitches. Some things, like pressed on washers, they don't have though. Dealer only. I guess J yard, too
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
look at the chart and make your decision i would bolt on a turbo with any bolt i could find in my folgers coffee tin.
Yes, stainless would be strong enough, but the problem will be that there's no antiseize that will survive at that temp, resulting in galvanic corrosion making the bolt unremovable.
Fastenal will have or can order whatever size you need.
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 05:51 PM
mirabile4runner
09-03-2015 07:15 AM
