seafoam
Old 12-29-2007, 05:45 PM
camo31_10.50's Avatar
seafoam
just ran the seafoam through my truck..(1980 yota 4x4 20R)..and it didnt seem like it did a damn thing...it kinda made it idle a little bit better...but not much...i just put it in the carb...is there anywhere else i should put it (i.e. crankcase gas tank...anywhere)...didnt smoke hardly any...i figured it would smoke like B@#$#...but it didnt...any info would be helpful....thanks
Ken,
Old 12-29-2007, 06:14 PM
linuxrunner's Avatar
How long did you let it sit before you started it back up again?
Old 12-29-2007, 06:16 PM
fork's Avatar
x2
Old 12-29-2007, 06:59 PM
the first time i did it...i let it set right at 6 mins...the second time i did it..it sat prob close to 10..did i not let it sit long enough....
Old 12-30-2007, 02:38 PM
Adam F's Avatar
how much did you suck up
Old 12-30-2007, 02:55 PM
infiltrator's Avatar
let it sit an hour and see what happens.
put it in the gastank
Old 01-02-2008, 08:46 AM
mkgarrison5's Avatar
this is what i do and i know this works very very well from past experience.
2 can of seafoam in the tank with 4-6 gallons of fuel to mix, run till almost empty
then take 1 can and in 1/3 increments suck it up via the pcv valve or brake booster and let it the first sit for 15 mins, 2nd for 30 mins and the last of it leave in there all night.. burn it out when you drive to work in the am..
change the oil after all of this too. most fuel cleaners leave residue and lots of additive mess in the oil so change it a day or so after you do this.
urabus
11-10-2015 07:38 PM
sanctfy
09-13-2015 06:33 PM
Boomer8404
09-10-2015 09:01 AM
accuracy
08-04-2015 08:05 PM
jjccamis
07-09-2015 04:00 PM
Quick Reply: seafoam
