Removing Spray Paint Coats
Old 08-11-2012, 04:52 PM
sp543's Avatar
Currently my 85 4runer is rattle canned flat black. Its chipping in some spots and peeling, so i want to explore my options for repainting it. Has anyone had success in removing spraypaint coats down to the factory paint, while keeping the factory coat? If so, what method did you use?
Thanks
Old 08-11-2012, 04:58 PM
nothingbetter's Avatar
the only way to do that would be to sand off the spray paint but not break through the factory paint...it its still all there.
Old 08-11-2012, 04:59 PM
Teuf's Avatar
Looks like you need to sand down to the original paint. Now way around it. Good luck and post some pics it will help your cause.
sp543's Avatar
any idea on what grit i should try first? i dont need to keep the factory paint, but it may be nice to not have to repaint it.
Old 08-11-2012, 05:03 PM
Teuf's Avatar
No matter what you sand off you will have to repaint or have a scuffed and scruffy truck. There are no easy do's on truck painting. There is only one way.
Old 08-11-2012, 05:06 PM
sp543's Avatar
if it ends up looking shotty and awful, which is probably will, atleast ill have a better base to start with when i paint it right. Im thinking the marine paint roll on method, have a friend who did it and it came out great and saw it on a few other forums too.
Old 08-11-2012, 05:08 PM
myyota's Avatar
You don`t need to sand anything, use lacquer thinner and go slow and you will get the spray paint off. Ive done this many tines to remove spray paint or over spray.
Old 08-11-2012, 05:09 PM
sp543's Avatar
Originally Posted by myyota
Use lacquer thinner and go slow and you will get the spray paint off. Ive done this many tines to remove spray paint or over spray.
applying with a rag and scrubbing it off or what other method?
Old 08-11-2012, 05:10 PM
Teuf's Avatar
Good point myyota. I forgot the liquid method.
Old 08-11-2012, 05:12 PM
myyota's Avatar
Yea, just use an old rag and take your time and you wont damage the original paint.
Once your done wax the original paint and it should look good.
Old 08-11-2012, 05:13 PM
sp543's Avatar
Yea, just use an old rag and take your time and you wont damage the paint.
Awesome, thanks for the help. I doubt it will be in good shape if someone painted over it, but its worth a shot
chukarhunt
12-08-2019 11:39 AM
Jcrawl94
10
10-24-2015 04:34 PM
09-04-2015 09:27 AM
jjrbus
08-10-2015 01:09 PM
58rennur4
08-04-2015 08:49 AM
Quick Reply: Removing Spray Paint Coats
