Remove unneeded EFI fuel pump?
Old 05-30-2013, 04:09 AM
Waylayer's Avatar
Have 3vze swapped with 22r. The electric fuel pump is still in tank, replacing the fuel pump bracket because lines are rusted out, staying with EFI bracket because bolt holes match up and fuel guage. Thinking that leaving the fuel pump in tank and have mechanical pump pull fuel through it may cause a restriction. Other option would be to remove pump and extend the line to bottom of tank. Not sure if it would make a difference. Any ideas?
Old 05-30-2013, 06:36 AM
Waylayer's Avatar
Got it figured out, cut main fuel line from inside old bracket, took fuel pump off too. Connected old fuel line to new bracket main fuel line with the rubber hose connection. Hooked fuel pump up to electric connector and hose clamped it to bracket but left it unhooked to line so that the fuel guage will work but fuel line is not restricted by flowing through it. Ill have to post a picture.
Old 05-30-2013, 06:58 AM
redbayredneck's Avatar
Just curious, Why not just use the Electric fuel pump and get one of the block off kits that deletes the mechanical fuel pump?
Old 05-30-2013, 10:03 AM
Waylayer's Avatar
this was kinda basic and works.
Old 05-30-2013, 10:22 AM
85TurboRunner's Avatar
Did you add a filter to the pickup?
Old 05-30-2013, 09:45 PM
Waylayer's Avatar
its got an external filter on the fuel line, should have one on end of pipe in tank but that will have to wait till a later date.
Old 05-30-2013, 11:18 PM
wyoming9's Avatar
Red face
I am curious just how does a fuel pump also do double duty as the sending unit for the fuel gauge????
Old 06-02-2013, 04:34 PM
Waylayer's Avatar
maybe it doesnt, I dont know if the other wiring hookup going into the top back of tank is fuel guage or if fuel gauge is part of fuel pump.
Old 06-02-2013, 04:36 PM
Waylayer's Avatar
now with bypassing the EI fuel pump the truck is running alot better.
Old 06-02-2013, 06:10 PM
Black_1985_SR5's Avatar
wait a minute let me get this right you chose to do a 3vze swap?
Old 06-03-2013, 05:53 AM
Waylayer's Avatar
I blew the 3v motor, decided to go with a 22r swap. Wanted to do V8 swap but didnt have enough $$ to go that route and deal with the gas guzzling.
smthwsn357
05-01-2024 07:28 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Remove unneeded EFI fuel pump?
