One Man Towing
One Man Towing
I'm thinking about buying an 89 4runner, and same yr parts car.
To get the parts car home, I'll have to tow it solo.
Is the steering setup such that the wheels will track the path of the tow vehicle?
Thanks
Thanks
The safestway to tow a rig with one person is a tow truck. You can't apply the breaks if you're towing by strap with no one in the towed rig.
The only other option is a tow bar or tow dolly. With the tow dolly (front tires ride on the dolly off the ground) you don't need to worry about the tracking, it tracks like pulling a trailer.
With a tow bar you will need to either lock or block the steering wheel and even then it might tend to wag like a tail on a dog
If your rear wheels of the vehicle you are towing are on the ground, make sure to remove the rear driveshaft otherwise, you can damage your transmission (auto tranny only... if it's a manual tranny, I believe you can just make sure it and the transfer case are in neutral? somebody else can confirm that.)
Thanks for the input guys.
Adam F...You're correct about the steering wheel.
If anyone searches this site in future, I'll post what's said in the "Haynes" manual...
"...can be towed with all 4 wheels on the ground, provided speeds do not exceed 35 mph, and the distance is not over 50 miles...transmission and transfer in neutral...steering unlocked..."
I agree. I have used a tow bar for years, and as long as the steering is good on the towed vehicle, it should track right behind the tow vehicle. The only tricky part is if you try to go up or down a driveway ramp at an angle, then the rear steering can get mixed up. In most states, you still need to have a working set of brake and turn signals on the towed vehicle.
Location: Houston (home), Atlanta (school), Cincinnati (work)
And from what I've read (From Marlin crawler himself, trans/transfer guru) you need to remove the rear drive shaft, due to the way your trans and transfer are oiled. With power from the motor, the trans is properly oiled. If its just spinning from the rear drive shaft rotating, your going to starve your bearings. Just pull the rear drive shaft. Heck, I'd go ahead and pull both.
What I meant was a working set of brake lights and turn signals.
turn the key one notch and your steering wheel will unlock
Cycles
09-29-2015 06:37 AM
Odin
09-26-2015 06:56 PM
Toys4parts
09-26-2015 01:56 PM
