Lube the chassis?
Lube the chassis?
I am going to take my 4Runner for an oil change, and noticed that on the coupon, it says "Lube the chassis."
Just curious as to what this procedure exactly refers to? I feel like a super noob asking this...
It used to mean shoot some grease in all the nipples on the suspension and driveline. Now most vehicles have everything sealed so there's not much to lube. On 4Runners the driveshafts still have greaseable U-joints.
Oh, so just shooting some grease into the zerk's, right? For some reason, I just thought they were greasing the frame, so I was kind of confused.
I like that Toyota gave us that little card in the sunvisor with the DS lube points. The oil change people always look at me funny when I hand it to them....
They Stick a grease gun on the fittings, 3rd Gen 4runners have 8 Fittings on the drive shaft and they aren't too difficult to grease. I Do my own Oil Changes, I don't trust any of them, I work at an Oil Change Place (Just for the money I hate the job, mainly because of the idiots that seem to work in that part of to auto industry) So most of them don't even know about Zerk's on the Drive Shaft, they just check for Grease fittings in the front suspension.
I've also heard of people spraying down their chassis with oil to prevent rust. Don't know if that has anything to do with "lubing the chassis". Never actually did it myself.
They are listed in the '85 FSM, search for a copy on-line os see below:
- http://www.4crawler.com/4x4/FSM.shtml
Basically they are on the front and rear drive shafts, fittings at each joint and slip yoke on each shaft.
here's a link to the thread which includes the replica of the visor card for most IFS trucks.
https://www.yotatech.com/forums/f116...r-card-235736/
it's also a good idea to add some grease to the turn stops which are responsible for that scary creaking sound some of our trucks make when performing a full-lock turn.
add to that list, some lithium white spray to the door check rods...
...and some dry graphite lube to the key cylinders...
I pictured in my head some guy in coveralls under a car with a tub of grease rubbing it on the frame rails by hand.
They are listed in the '85 FSM, search for a copy on-line or see below:
89fourrunner
02-17-2016 06:52 AM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
2005, 2005tacoma, 4runner, 89, chassis, ds, grease, gun, lube, lubing, lubricating, lubrication, points, tacoma, toyota
