Looking for recommendations on products remove old undercoat
As the title says I'm looking for a product that can be used to remove old dried up undercoating off of the frame on my 84, I plan on stripping it down and re coating everything, I've seen some products out there just wandering if any of yall have had any luck with a specific product, thanks in advance!
If you already have the body off easiest would be sandblasting.
I am definitely using a 5n1 scraper to chip off what I can, which covers alot of the back half however the front half of the truck has stayed so saturated with fresh oil from the timing cover seal leak the p.o. never fixed it's all rather soft in a way, sand blasting would be great as I do have the cab and bed removed but I don't have the air pressure needed nor the equipment do it at home,
and for the wire brush idea it just gets gummed up with the melted rubber product...
I may be able to use the torch idea to heat it up then scrape it off while in liquid form... wonder how much a local company would charge to sandblast a frame...
What kind of companies do that? body shops, welding and fab shops? I have no idea I've never had to look into that
I was kinda hoping for a spray on product kinda like aircraft stripper that will break it down and make it easier to scrape off or hit with the pressure washer
I was kinda hoping for a spray on product kinda like aircraft stripper that will break it down and make it easier to scrape off or hit with the pressure washer[/QUOTE]
I'd stay away from paint stripper on the frame. Reason is, it's nasty stuff that will make it's way into places you don't want it, like inside the frame. Also on a piece as big as a frame, you'll somehow get it in your eyes, ask how I know.
For small parts I've used it, but as soon as I get a sandblaster, I'll never touch paint stripper again.
A good body shop would have a sandblaster, but they're real cheap at harbor freight. You can use canvas or tarps strung up with rope as a temporary 'blasting cabinet' if that matters.
Maybe a blaster would be a good investment considering I still have to prep the cab doors and hood all for body work and paint may be worth my wile to hold off and invest in a decent setup to do all of the above, I'd probably just blast it out in the yard and blow the media away lol I couldn't imagine the mess I'd have to deal with if I used it inside my garage
if you are gonna do it outside you might need to look into a biodegradable media like walnut shells
https://turbofuture.com/industrial/W...-Soda-Blasting
A after some more research I found out that a group of guys that restore older porsches have a similar product in the floor pans that is used for sound deadening. They have been using an oscillating tool sold at harbor freight and say it's an amazing tool for this job, I'm going to swing by my local hft and pick one up probably this weekend and see how that works out for $25 I'm not risking much but if it's as good as they say it is it will save me a ton of time effort and most of all leave more money for parts..
lalojamesliz
09-21-2016 09:56 PM
