Line-X
Line-X
I talked to the local Line-X about spraying my bumpers and rocker panels. They quoted me a minimum of $1000. A thousand bucks?? That's crazy. What do you guys think?
I have my front bumper Line-X'd with the Kevlar, didn't cost me anything because I was working there at the time but, I'm going back to get my rear bumper done because of the look, protection and durability.
You should check into that Durabak product. 4ever4running from Austin did his hood and rockers, looks excellent. That and it is a do-it-yourself project.
http://www.herculiner.com/
I've read a lot of good things about this product from a lot of different threads here on yotatech. When I get around to doing my rocker panels I'm gonna pick up the diy kit from schucks for about 100$, give or take.
I know the dupli color they sell at auto zone isn't the best stuff in the world but I was thinking of doing my floorboards with it. Think it will hold up.
I wouldn't recommend the do it your self stuff. My brother used it on his bed and its awful compared to my line-x bed. Although $1000 does sound like a bit too much, the product will be 10 times better.
My grandpa left me this truck when he passed away and as far as I can tell the only real problem with it is the floorboards. Any other long term options to protect the floor other than bedliner??
I would not use duplicolor crap, does not hold up. I used it in the rear of my runner to try it out, after that I spent the $1000 at linex, but that was front/rear/sliders/runner floor pan front to back and about 3" up the side and all sandblasting.
OP-
Your local line x guy is giving you the shaft. Should be around $400-500 for the bed and about the same for all bumpers and that should include sand blasting, depending on the rate per hour.
OP-
Spray On Bedliner
After a little research on spray on bed liners, I found a company called Bullet Liner. Come to find out, this company was started by the guys who started Line X. They did have a dealer in So Cal where I'm from and in looking at the finished product vs Line X vs cost I couldn't be more happy with my truck. I talked to the owner of this shop Tim and they got my truck in and out in about an hour. Thanks Bullet and Tim! The number is 760 439 2969
Well cheaper for the same type of product is a good thing. I have my front bumper Line-X'd as well as my storage compartment in the back. I think it's a great product.
