| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
isr mod?
#2 (permalink) |
Ok, I'll say it . . . . it's got me baffled. You might just go through everything you touched during the installation to make sure that everything got put back together right. I can only speak from my own brain fades. When I did the ISR install I didn't have much light when I was finishing up. I went to start the truck and . . .. . . plenty of cranking but no combusting. It didn't take me long to realize that I hadn't plugged the coil wire back in after I'd removed it to make the ISR install easier.
Another idea, if you tweaked the brass couplings much during the install you might have torn one of the rubber grommets. The holes in the ISR tube weren't deburred during manufacture and will cut/tear the grommets pretty easy. (Again, I know this from experience.) That could cause air to be introduced between the AFM and the throttle body = BAD. I don't see how the ISR mod, when installed properly, could cause worse mileage.
__________________
1990 SR5 V6 Standard Cab Short Bed 4X4 5 Speed Last edited by Snorkeldepth; 05-05-2006 at 11:34 AM. |
#3 (permalink) | ||
Sponsoring Member
Quote:
Quote:
The ISR mod (on the 3.4 or the 3.0) improves the throttle response by reducing the volume of the intake path from air box to throttle body. How bad did your mileage get? (before/after numbers would be helpful) Where are you in the world? What's the weather been like? What's your driving style like?
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#4 (permalink) |
The only way I could see it causing worse gas mileage is that after you have installed it you got a heavier foot.
__________________
-- '90 4Runner 2Dr 3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust |
#5 (permalink) | |
Quote:
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#6 (permalink) |
ok got some more bad news, exhaust leak...could that be what is causing poor gas mileage, i don't think it could be the isr mod either, but the exhaust leak and the isr mod happened about the same time...?
#7 (permalink) |
Depends on how much back pressure is being lost.
__________________
#8 (permalink) |
did you remember to pull the ECU fuse after the instal?
__________________
-John- 1997 LTD- ARB Bumper, Deckplate and ISR mod, Diff Breather, TRD Exhaust, Much More to Come |
#9 (permalink) | ||
Sponsoring Member
Quote:
Quote:
__________________
#10 (permalink) |
Whats the ECU fuse?? also i went to my local muffler shop and im getting a dual catback exhaust sysyem all mendral bent. He said he bend it all for $200 plus the cost of the muffler of my choice, all 2 1/4 piping. also theres this store that sells adaptors for the stock air box that removes the enitre box and replaces it with a cone filter, between these two things im hoping ill get a little better gas mileage, as of right now im getting 13 city, i will try and get some pics posted as soon as this is all done!
#11 (permalink) | ||||
Sponsoring Member
Quote:
The purpose is to reset the engine computer (ECU) so that it will re-adjust to the difference in airflow response with the ISR mod. Quote:
Quote:
Be careful. Quote:
Also, where is the exhaust leak you mentioned? Before or after the front O2 sensor?
__________________
#12 (permalink) |
Stock piping is actually 1 7/8" on the 3vze(just looked it up in my catalog) taking it up to 2 1/4" should be just fine any more and you will regret it. I honestly do not forsee resetting the computer on an obd1 system to be the problem you are having.
Are you sure everything else is running fine? Did you put cheap gas in? Are you pinging badly? Mark has it with the cone filter. If you take the thing offroad then leave your airbox on.
__________________
#13 (permalink) | |
Quote:
89red4x4yota if you want dual exhaust then you will need to go with smaller pipe. 2.5 on a single system on a 3.0 is on the big side unless you are boosted or have rebuilt the motor & are near 200 whp. Dual 2.5 will kill your scavaging effect & thus you will loose tq & hp on a naturally aspirated eng
__________________
90 4runner-3.0-5spd For sale lifted 2nd gen 4runner Last edited by NC-B17A; 05-07-2006 at 08:26 AM. |
#14 (permalink) | |
Sponsoring Member
Quote:
People are used to saying "back pressure" in this sense because increase the tube size decreases back pressure, which ALSO reduces the savaging effect, which is trouble. But yes, you're right.
__________________
#15 (permalink) |
ok change of plans, im going to go with a borla muffler, with a simgle outlet of 2.25 tubing, and im going to make a heat box for my intake, about to go get my new digital camera so ill try to gets pics up when its all done in maybe a week
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Yet another ISR mod... | Tigerstripe40 | 86-95 Trucks & 4Runners | 0 | 11-25-2006 10:02 PM |
| ISR Mod | MysticGold04 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 04-06-2005 09:34 PM |
| I am about to do the ISR mod | wvuviv30 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-17-2004 10:25 PM |
| 1/2 ISR mod | wynn | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-29-2003 01:40 PM |
