how many times can i go in water
Old 12-27-2005, 09:33 PM
99SR5's Avatar
i just went wheelin today and went a little deep in the water. what happens if the water goes above the rear axel. will it mess anything up the first time i do it.
Old 12-27-2005, 09:42 PM
marko3xl3's Avatar
If you do not have an extended rear breather installed, there is a chance that your differential sucked some water into itself. When you submerge your differential, depending on how long and the temperature difference, the breather might open and 'accidently' suck in some water.
Your best bet would be to check your rear diff fluid and install an extended breather. There is a write-up in the tech section about it.
Other than the diff, the only other thing to worry about is not to get water into your intake which is located in the front right fender.
Old 12-27-2005, 10:47 PM
Sponsor
Tofer's Avatar
this is how i did my diff breather mod.. it works perfect. http://www.wattora.com/mods/diffbreather/ i put the end up near the gas filler hole, i figure if water is that high, my rear diff is the least of my worries.
Old 12-28-2005, 05:22 AM
4Hummer's Avatar
Build a snorkel, Extend front and rear diff breathers, seal everything else.
But no matter what you do your Toyota will not be a submarine.
Take a close look at the water line INSIDE the truck
Old 12-28-2005, 06:29 AM
Intrepid's Avatar
IF you get mud into your stock breather it can clog which can cause your axle seals to blow, I believe our good buddy Gangbang had an issue with this. Extend your breather, change your diff fluid, do it soon!
Old 12-28-2005, 08:26 AM
99SR5's Avatar
so what if i did suck in some water, how much water would it take to make some damage
Old 12-28-2005, 08:34 AM
4Crawler's Avatar
Check the gear oil in the rear axle (via the fill plug). It'll look like a milkshake if a lot of water got in. If just a little bit, that can be evaporated off with normal driving.
Old 12-28-2005, 08:36 AM
99SR5's Avatar
yeah i wasnt in there for long just a couple seconds
Old 12-28-2005, 08:54 AM
farmerj's Avatar
It doesn't take that long to get enough water in there to ruin your fluid. Depending on how good your breather is, you already may have water in there.
It is a cr*p shoot really. I have seen vehicles go in and out of water all day and not have water. I have seen vehicles drive through water once and they are filled enough to ruin a differential.
After our Flood in 97 and rebuilding axles, hubs and differentals on a daily basis, I simply avoid water when possible.
The only way to be save is, Everytime ou travel in water, pull you fill plug and visual your fluid. If it's milky, you got water.
On a side note, check your brakes too. You may have popped a wheel cylinder seal. It's happened and it sucks too. Water will leach into the entire system.
Old 12-28-2005, 08:07 PM
99SR5's Avatar
yeah i checked out my fluid and its ok. it got me scared though.
Old 01-04-2006, 02:32 PM
spindleshanks's Avatar
I Just installed the diff breather relocation (Thanks for the WaTTORA link, Tofer). I routed the hose up the fuel filler neck as they advised, and went one step further, having the breather protrude out into the fuel fill area, behind the fuel door. I removed the four screws, pulled the black plastic cowling out of the fuel fill area, and drilled a hole in it large enough to allow the threaded portion of the breather to protrude into the cowling, but not the hex-head portion. Fitting the breather into the hose was easy. Plenty of slack was left in the hose to allow flexing of the suspension, and I think the location of the breather behind the fuel door will be relatively protected. Zip ties (which, by the way, are mankind's greatest invention) secure the hose to the filler neck and to the loom that supports the E-locker wiring. Curiousity has me wondering whether I'll smell gear oil when I open the fuel door to gas up on a hot summer day. Who cares. Now I feel better prepared to take on the river in front of Medano Pass that flows in late spring/early summer. Yeehaw
Old 01-04-2006, 03:29 PM
jsnby's Avatar
what are you guys doing for the front diff, transfer case, and transmission?
Old 01-04-2006, 03:30 PM
Crux's Avatar
This has been on my list to do forever, I even have all the parts.
Someday I gotta get it done...
Old 01-04-2006, 05:32 PM
midiwall's Avatar
You may, but that's a feature... you know the breather's working if you do!
Old 01-05-2006, 05:38 PM
The whole job was done for $7.60. I got the fuel hose from my CARQUEST hookup for .43/ft. Note that the writeup called for 8 feet of hose...I only used 5 feet. I jacked the truck up and put it on stands, so that the rear axle was fully articulated, to see how long the hose needed to be to allow for flex. I got plenty of slack with the 5 foot section of hose.
I checked at Checker Auto and they wanted .10/inch for their fuel line...ridiculous! The union fitting from Toyota cost $4.50, also ridiculous and those ass clowns had to order it in.
Old 01-05-2006, 05:39 PM
The front diff breather is located in the engine compartment. I don't think there are any breathers on the TS or Tranny. Anybody?
Old 01-05-2006, 06:18 PM
jsnby's Avatar
you mean after you extended it, right?
Old 01-05-2006, 11:54 PM
midiwall's Avatar
Actually, on a 3rd gen and beyond, the front diff breather is already extended from the factory. It's been a long standing question as to why Toyota would do the front and not the rear from the factory.
Old 01-06-2006, 07:51 AM
hill's Avatar
here is a really silly question...how do i change/flush my rear diff fluid....?
Old 01-06-2006, 08:03 AM
JHupp's Avatar
just ordered my breather parts today, don't think they would help much in a situation like 4hummers though. one easy mod, that I completely missed, like finding stuff like that though
Quick Reply: how many times can i go in water
