How do you measure exhaust pipes diamater.. I.D. or O.D?
Feeling a little dumb here, but how are exhaust pipe and mufflers measured? Does it go by the inside diameter or the outside diameter?
Any help would be appreciated.
Thanks!
Thanks!
Actually it kind of depends. Mostly it is measured by ID, but if you are getting fittings, mufflers, etc. then you may need to deal with OD as well. For example, most exhaust tubing is 1/16" wall, so with 2" ID and a pair of 1/16" walls, the OD is 2-1/8". So if you want to slip a fitting over that pipe, you would need 2-1/8" ID on one end of the fitting and whatever size on the other end.
kawazx636
07-03-2023 03:03 AM
justdifferentials
Just Differentials
06-13-2022 07:40 PM
runnermedic
13
09-21-2015 05:20 PM
