YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-18-2007, 04:47 PM   #1 (permalink)
4banginRunner's Avatar
diff mounting studs
does anyone know a part # and/or where i can get stock replacement differental mounting studs, just got an IFS rear axle from the junkyard today minus the third, a couple of the mounting studs are snapped
i already read up on converting to bolts, but i'd really like to stick with stock replacement
thanks
__________________
87 Toyota 4Runner SR5
22RE--5spd swap (W56-A) w/Hurst t-handle shift knob--V6 4.56 swap--1.5" BJ spacers, AAL's & ZUK mod--'85 brown/tan interior--sway bar removed--2.5" Flowmaster 40 series--2.25" exhaust--Battery/Intake swap--late style steering box swap--V6 calipers--1" MC--34" Nitto's--Consistent 22MPG Daily Driver
79 Toyota Longbed 4x4
Awaiting time, money & some parts
previous
82 Longbed 4x4 Pickup
90 Toyota 4Runner<3 RIP
95 Jeep Grand Cherokee
4banginRunner is offline
Sponsored Links
To remove this ad, register today!
Old 09-18-2007, 11:38 PM   #2 (permalink)
MudHippy's Avatar
Quote:
3rd member mounting studs:
long (total of 2) - 90116-08226
Short (total of 8) - 90116-08235
Nuts for above - 90170-08204
Washers for above - 94512-00800
http://www.4x4wire.com/forums/showflat.php?Cat=&Number=27237&page=0&view=collaps ed&sb=5&o=all&fpart=1
It says those are for an 8" front axle, but the rear should be the same being's that it's the same 3rd member.
__________________
Sonoran Steel Early IFS Truss
Your IFS is SPINELESS without it
SonoranSteel.com
I'm Cuckoo For YOTA Trucks!
MudHippy is offline
Old 09-19-2007, 01:56 AM   #3 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
90116-08235
I submitted those part numbers as rear axle numbers from my 88...but they were categorized as front axle parts. The "long" studs are for the elocker axle for mounting the motor.
Adam F is offline
Old 09-19-2007, 07:27 AM   #4 (permalink)
thanks for the #'s
any idea's on price?
__________________
previous
Old 09-19-2007, 07:56 AM   #5 (permalink)
4Crawler's Avatar
You can also use some M8-1.25 x 35 and 40 mm long allen screws. Install from the inside of the flange facing out.
Otherwise, I have a few spare short studs if you want to keep studs in there.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-19-2007, 09:22 AM   #6 (permalink)
i seen the allen screw conversion somewhere but i cant find it now
anyone have a link?
:edit: found it on pirate, looked up the materials on Fastenal, comes to about 13 buck with extras, woohoo, i'm goin to fastenal tomorrow!
__________________
previous
Old 09-19-2007, 09:53 AM   #7 (permalink)
4Crawler's Avatar
http://trail-gear.com/toy-diffstud.html
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-19-2007, 09:57 AM   #8 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
We have a diff stud/bolt kit.
http://www.wabfab.org/products/diffe...ferentials.htm
waskillywabbit is offline
Old 09-19-2007, 05:56 PM   #9 (permalink)
MudHippy's Avatar
Quote:
Hmmm, was there an e-locker available in 87-88? Not that I have a better answer as to what they're for.
I have 2 rear axles. One that was stock on my 88 pickup, the other I pulled off an 87 4Runner.
They both have 8 short studs, and 2 long studs for mounting the 3rd member. The 2 long studs are located in the same holes on each axle. 1 in what would be the 12:30 position hole. The other 1 in the 5:30 hole.
__________________
SonoranSteel.com
MudHippy is offline
Old 09-19-2007, 06:03 PM   #10 (permalink)
4Crawler's Avatar
No e-locker at that time. All the 3rds I have seen have two longer mounting studs, 4-cyl, V6 and high pinion. Not sure if the long ones are the same length as the e-locker 3rd. 35mm and 40mm are about the right lengths for the others.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-23-2007, 01:45 AM   #11 (permalink)
Adam F's Avatar
Like Roger said, not available for that year. I retrofitted a 99 TRD Tacoma elocker into my 88. I was mistaken when I said the long stud part number was for the elocker motor. The correct part number for the longer elocker motor studs is 90116-08330. Sorry for the confusion!
Adam F is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
WTB Top plate spacers, extended studs, diff drop One_96TR4 Axles/Suspensions/Tires/Wheels 1 06-14-2007 06:36 PM
wheel studs mp101v 86-95 Trucks & 4Runners 0 12-29-2005 11:00 AM
Chains Vs. Studs bob200587 Tires & Wheels 7 09-11-2005 11:58 AM
Bolts or studs desert whomper 95.5-2004 Tacomas & 96-2002 4Runners 0 11-20-2004 04:12 PM
wheel studs ellzzs 95.5-2004 Tacomas & 96-2002 4Runners 12 12-08-2003 07:48 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
