Compression myth.....
Old 01-22-2011, 05:04 PM
The Rockin Hoskin's Avatar
Hey so I just got a new (to me) carberated motor for my rig. I want to switch it over to efi (what the truck came with originally). A wile back I had heard from a friend that an efi engine might not have the same compression as a carberated one ... is this true?? I personally don't see how this is possible but I just wanted to double check. Thanks guys
Old 01-22-2011, 05:13 PM
yoterr's Avatar
nah people swap all the time...and ive never heard of different compression ratio's effecting it? pretty sure there the same if its a 22r...carb or efi...turbo is a different story
Old 01-22-2011, 05:28 PM
K thats kinda what I thought... Thanx
Old 01-23-2011, 07:32 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
x2 on the RTE... As far as I know the only engines with different compression ratio's are RTE's and a 20/22r Hybrid...
PS, and any collaborated effort with either an RTE head or pistons.
Old 01-24-2011, 05:43 AM
xxxtreme22r's Avatar
compression ratios for toyota engines. http://www.toyoland.com/engines.html Some are missing I know.
Old 01-24-2011, 06:54 AM
4Crawler's Avatar
Some information below as well:
http://www.off-road.com/trucks-4x4/t...ion-18589.html
Old 01-24-2011, 07:49 AM
Originally Posted by 4Crawler
hmmm conflicting info: Not that I am saying off-road.com is wrong though.
22R (Carb), 2367 cc disp, 9.0:1 compression, 100 hp
22RE (EFI), 2367 cc disp, 9.4:1 compression, 116 hp
22R 81-83 2367 96@4800 129@2800 9:01
22RE 83-86 2367 105@4800 137@2800 9:01
Old 01-24-2011, 04:28 PM
never heard of a 100 hp 22R... It's always been 96.
And that's further backed up in my Chiltons.
Old 01-24-2011, 08:41 PM
Numbchux's Avatar
The higher the compression ratio, the more sensitive the engine becomes to ignition timing and Air/Fuel ratio. As those things become computer-controlled, it becomes possible to up the CR without risking longevity issues.
So yea, typically speaking, a carbed engine will have a slightly lower CR than a FI version.
This doesn't mean they can't be run in the other configuration. But it does mean that a Carbed engine running FI will not run quite to it's potential, and an FI engine with a carb will be just fine, as long as it's kept in adjustment.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
dzldust
7
10-06-2015 05:39 AM
Quick Reply: Compression myth.....
