Adj air pressure switch
Does anyone know where you can get a 12v adj air pressure switch. I need one that is adjustible in the 20-50ish range.
Thanks
Thanks
I've seen a bunch that are like 90-115psi, but never 20-50.
WAIT, here's one, but its 115vac, you could probably use a relay or something to make it work
http://www.surpluscenter.com/item.as...42&catname=air
http://www.streetpros.com/search.php...ssure%20switch
http://store.summitracing.com/egnsea...nresults=false
http://www.airride.com/productinfo/components.asp
http://www.airbagit-store.com/produc...t.asp&ID=95901
http://search.ebay.com/search/search...tSearch=Search
http://www.surpluscenter.com/sort.as...ssure%20switch
I need on that is adj in the 20-50 range, not 20 on 50 off... but thats for the info...
WATRD found this one, but its $$$... I dont need one that fancy.. .but so far its all anyone can seem to fine..
skoti89
07-08-2015 12:05 AM
