97 runner has a whine in the rearend
Old 06-07-2012, 12:23 PM
Daryledj's Avatar
The rear end is a little noisy, does anyone know what could cause it. It whines and howls a bit.
Old 06-07-2012, 12:47 PM
badattitude's Avatar
Check the rear diff fluid level by taking off the top fill plug (diff oil should be up to the opening), if it is low you may have devloped a bad pinion bearing. Somtimes this is in conjuction with a cloged diff breather and leaking axel seals.
Old 06-07-2012, 01:30 PM
Daryledj's Avatar
Thanks. Ill check that out. Fortunately there are no leaks.
Old 06-07-2012, 07:11 PM
87slosohc's Avatar
Ujoint or flange movement?
Old 06-07-2012, 07:35 PM
Daryledj's Avatar
That was something I also thought of. Thanks?
Old 07-24-2012, 03:19 PM
Hammerhead 7's Avatar
is this something that just started or you bought the truck like that? If the gears have been changed ...the ring and pinion may not be matched, that will cause a howl.
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 97 runner has a whine in the rearend
