22RE Rough start, fuel pressure regulator?
Hi, my name is Jake and i'm having problems with my 91 yota starting, it turns over and fires once then dies, it'll do this a couple times then start at a real low idle unless i crank it over for about seven seconds then it fires and idles fine, it used to fire right up first turn of the key. I've asked a few people and they say fuel pressure regulator or fuel pump could be the problem?
I also have noticed that when its running and its cold if i push the brake pedal the idle drops then rises then drops again is this a vacume leak somewhere? or throtle possitioning sensor or something i changed that about a year ago
any help would be greatly appriciated Thanks,
Jake
Jake
Sounds to me like you may have two problems. Check the cold start injector for the start issue and clean the coolent passage through the iac for the surging when you hit the break.
update
alright so i flushed the coolant through the IAC passage and replaced the cold start injector, now it fires up first turn of the key but still has the idle surge when i hit the brakes... any more ideas?
i had the idle surge when hitting the brake. my idle was set too high. it should be at 750 rpm for a 22RE manual.
It is the computer restricting fuel flow when the brakes are applied. once i set the idle down to normal, it went away.
bigblue82
10
07-06-2015 08:27 AM
jmc88runner
06-18-2015 03:39 PM
