What GEARS & TIRES are you running?
33x10.5-15 BFG A/Ts with stock 4.10s. the 88 22RE, even with it's second rebuild, cannot maintain speed on a hill.
on highways, i drive it floored in 4th. on a downhill it goes up to 70-75 at 4k. on an uphill it drops to 50-55 at 28k. then i gotta shift to 3rd.
5th is hibernating until i get 4.88s or 5.29s
#26
88' 22RE 5spd
ALL on 31X10.50 R15
Was on OE 4.10's
Just swapped to 4.56 from ADD v6 auto
prior to the swap, hills were a loosing battle
hills now, acceleration is easy in 5th with traffic
ALL on 31X10.50 R15
Was on OE 4.10's
#29
31x10.50 on stock rims and stock gears auto tranny and it's slow realy slow
what would you guys recomend for gears?????? any help
i use it on the freeway 80% of the time it's a lovely 22re efi
#33
Might as well do an engine swap, lift it 6"s, put in 5.71s, and get some 37" tires. No really, 4.88s and 31s with a 22re should be perfect or 5.29s with 33s like camo said.
#34
33x12.5 with 4.88 little slow up here at 5000 to 7000ft but I can almost go 80 on the highway so long as I don't hit any hills. I'll probably go down to a 10.5 tire to reduce rotating mass and hopefully liven things up a bit.
#37
86 4x4 22re 5spd, 5.29's and 30x9.50R-15's.
According to the radar sign, when my speedo says 70mph, I'm actually going 55.
55mph = 3000 rpm right now
I don't notice hills, up or down lol
