Towing with a 89 Pickup.
Alright my story, I moved to a different city. Left most of my stuff at my old place, now I am going back to buy a truck and rent a uhaul trailer to move my stuff.
The uhaul is a 12x6 trailer, ill link it below. Honostly it shouldent be very heavy, ive moved alot in 2 car trips already. Just a couch (basic couch, leather, no recliners, its really light) a couple book cases, and other stuff other stuff a college kid might have. (200-300 pounds max)
http://www.uhaul.com/Reservations/Eq....aspx?model=RV
They didn't have any smaller for that moving date...
The truck I am buying is a 1989 Toyota Pickup, ext cab, 4x4, , v6, auto. I was planning on using the stock ball on the bumper to tow the trailer. Is this a terrible idea? The drive is about 6 hours. What do you guys suggest? Sorry if this is posted in wrong section, I'm new here :b
Those trailers arent all that light. I highly suggest you get a real hitch if you want to attempt this. The bumper is not rated for it. Even with a hitch your pretty close to the 3500lb max towing capacity.
If you do it, lock the trans out of overdrive and take it easy.
When I was on the website they asked for make/model/year of the tow rig, and then recommended trailers that it can haul. The one I selected was in the list.
Yeah, thank you. I'll give them a call and figure it out, if not ill rent a moving truck with a tow hook or something on the back to move the truck :b
If you use a Dolley to tow your new truck behind a u haul truck be sure to take a few minutes to remove the rear drive shaft. Toyota transfer cases don't get lubed properly when flat towed.. plus you run the risk of destroying your transmission etc. I learned the hard way when my transmission went into gear, it was a costly lesson for me to learn..
Good news, managed to get a smaller trailer http://www.uhaul.com/Reservations/Eq....aspx?model=AV 8x5, only 900 pounds empty, this guy should work just fine right?
