Steering Question?
Old 09-16-2006, 05:13 PM
BearsRunner's Avatar
Steering Question?
Hey all,
I have a 90 4runner 4x4, I bought used awhile ago. I was just wondering if anyone has a problem steering while in 4wd? I know that if you have a locker up front, you may have a tougher time turning. So I guess my main question is, does anyone have a problem steering in 4wd without a locker? I hope someone can help. Thanks, Bear.
Old 09-16-2006, 05:31 PM
Paul H.'s Avatar
As long as you are not using the 4wd on dry pavement, there should be no problem. I don't feel any difference between 2wd and 4wd in my steering.
Old 09-21-2006, 08:05 AM
When I am driving in in 4hi, I have no problems, except when I am making a sharp turn, or turning into my drive-way. Sometimes it takes a ten point turn if I back in!
Old 09-21-2006, 08:10 AM
YotaFun's Avatar
When in 4WD you steering becomes limited..
At least that the observation I have come too..
I have a 97' and step dad has an 02' 4Runner
And when we are in 4WD,
The only time it is noticed is when we have to make a really sharp turn.
But usually when in Deep or very slippy mud and deep or wet snow it is not noticable cause the car usually has it's little slip and give here and there...
So unless it is really really like that bad, I think you experiencing a normal function.
Old 09-21-2006, 09:52 AM
4Crawler's Avatar
In 4WD, the front and rear axles/tires are turning the same speed (w/ a part-time 4WD system, i.e. no center diff.). When you make a sharp turn, the front tires want to travel in a larger arc than the rear tires. So this causes the drivetrain to become bound up, making turning hard. One option is to shift out of 4WD before making the turn, especially if it is on a high traction surface. If you need low range, you could install a twin-stick shifter in the t-case or unlock a front hub.
Old 09-21-2006, 02:06 PM
Thanks, so this happens even when you do not have a locker?
Old 09-21-2006, 02:36 PM
4Crawler's Avatar
Yep, worse with a locker but still happens with open diffs front and rear. In effect, your part-time transfer case is like a locked diff., it allows for no slip front-rear, that is what causes things to bind up.
Old 09-21-2006, 08:19 PM
Thanks a bunch! That clears up my Q's.
glowz825
01-25-2022 09:28 AM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
gillesdetrail
08-03-2015 04:43 PM
bobpat
08-01-2015 09:25 PM
Quick Reply: Steering Question?
