Running hot Only while driving. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-08-2009, 05:03 PM   #1 (permalink)
OK im a " new " 93 4runner owner 125k. truck was running cold and could never get it to warm up ( or shift into OD ) i had to drive the thing for about 20 min before temp would get half way. so i changed thermostat only to find that previous owner took out the old one and left it open . now car heats up fine at idel , but when i drive it gets hot , what Gives. PLEASE HELP
GBRAZIL is offline
Old 12-08-2009, 06:27 PM   #2 (permalink)
myyota's Avatar
Check the radiator, it could be plugged, maybe thats why the previous owner removed the thermostat because it was over heating.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, Trail Gear High Steer, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, AFM Upgrade, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 12-08-2009, 06:33 PM   #3 (permalink)
yota8083's Avatar
overheating while running down the road = radiator stoped up. I bet one tank is hot to the touch and the other isnt. This means the coolant is not circulating through the radiator causing the overheating.
yota8083 is offline
Old 12-08-2009, 07:50 PM   #4 (permalink)
OK. sounds simple. but is it as simple as a draining it or a complete flush
Thanks for the help guys .
GBRAZIL is offline
Old 12-09-2009, 07:57 AM   #5 (permalink)
yota8083's Avatar
In this case I usually just replace the radiator. You could try flushing it first but I have found this usually doesnt fix the problem.
yota8083 is offline
Old 12-09-2009, 04:51 PM   #6 (permalink)
Well there you have it.. flush it and still gets hot when driving. guess its time to replace.
GBRAZIL is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
