Question on IFS Lift...
Old 09-03-2009, 02:42 PM
tumor21's Avatar
So i'm looking for a relitively inexpensive lift for my 87 4wd ext. cab 22re. A SAS is not in my budget and I keep landing on the ball joint spacer option. They all seem pretty much the same.
http://www.toyteclifts.com/index.php...mart&Itemid=72
http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
I'm probably going to get a diff drop kit (unless there is a reason to not get one) so my CV's don't crap out on me. Question is... Add-a-Leafs or Blocks in the rear? I'm getting kind of a split decision from everyone I ask.
(You get the idea)
Old 09-03-2009, 03:07 PM
1990mudslut's Avatar
From what I have heard bj spacers eat idler arms like candy.Can't say from personal experiences tho.I have a 3 inch body lift on my truck and it is great.It was like 200 bucks and makes working on my truck a breeze.
I don't think there is a need for the drop kit especially at such a low lift.Definitely blocks in the rear,add a leafs make leaf springs really hard and make a truck ride like poo IMO.
Old 09-03-2009, 03:14 PM
xXbrutalXcoreXx's Avatar
Instead of blocks or AAL's why not get longer shackles?
Old 09-03-2009, 03:54 PM
yoterr's Avatar
x2 on longer shackles, you get same ride without the ill effects of a block, and if you go with BJ spacers go with 4crawler, hes got some good stuff, and the diff drop is if you run ur 4wd alot on road, if you use it only in off road conditions i wouldent worry about it cuz your cv's only see wear from tall angles when the hubs locked in
Old 09-04-2009, 05:11 AM
Junkers88's Avatar
X2 on getting the BJ spacers from 4crawler. I've put them on two rigs and never had an issue. In the rear I'd say go with longer shackles, I added coils to mine but that may not be something you want to dive into.
Old 09-04-2009, 05:44 AM
yoder519's Avatar
get em from 4crawler. i got his bj spacers and a superlift 2inch AAL with a 2inch 4crawler bodylift. i think its a really good setup. neverheard of the spacers messing up idler arms, but if you put on bigger tires and wheel it then yea idler arm is the weak link
Old 09-04-2009, 06:08 AM
Ardent's Avatar
I have a set of 3.5" blocks and u-bolts if you're interested. Shoot me a PM if you are. I only ran them on the truck for about 2 months before I got replacement springs. It would give you a little rake, but if your springs are like most (saggy) they would probably work well.
Oh, and I would definitely get the diff drop.
LMK.
Nate
Old 09-04-2009, 07:37 AM
4Crawler's Avatar
See below for some pros and cons of each:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
Old 09-04-2009, 09:24 AM
AxleIke's Avatar
Blocks are quite possibly the worst way to do the rear.
They can spit out and be dangerous. Watched it happen. Took out a driveline as the axle slid backward along the spring.
Just get longer shackles. Its cheap, and easy to do, and much safer.
Old 09-04-2009, 10:55 AM
tumor21's Avatar
Think I'm leaning to the shackles approach. everyone seems to be a 4crawler fan so.. that will most likely be my next stop. Thanks fellas!
Old 09-04-2009, 11:54 AM
tumor21's Avatar
Now that I think about it... Does anyone have any pics of their rig (86-88 pickup, 86-89 Runner) with a ball joint + shackle lift?
Would love to get a good idea of what I can expect.
Old 09-04-2009, 12:10 PM
4Crawler's Avatar
Here is a '94 pickup wit+2" rear shackles and torsion bars cranked up about 1.5":
- http://www.4x4wire.com/toyota/hottoy/west/
Also has a 1" body lift.
delmert
09-30-2015 04:34 PM
88sasturbotoy
08-11-2015 01:56 AM
Gevo
07-29-2015 11:15 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Question on IFS Lift...
