Need help with sas
exactly--the search function works pretty good.
It also helps to know what Toyota you are planning this on
-86-95's trucks can use a stock toyota SA axle
-a 95.5-2004 Taco the transfer case is a DS drop so you are gonna need something like a Waggy axle with the pumpkin on the right side.
..why do you want to SAS?
here is some reading to wet your whistle SAS Folder all years...
the last 3 questions in newb tech has been this same question..
and if you go look at pirate4x4.com you will find a ton of info, but lurk..don't post
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
