my very sick 22-r eats fuel like i own a gas station
Old 09-11-2008, 05:05 PM
larmo's Avatar
Location: i live in ontario ca lived here for bout 8 years
Question my very sick 22-r eats fuel like i own a gas station
can any 1 out there plz tell me why my toyota 22-r gets only 8 miles to the gallon it has a small exhost leak its driving me to the poor house and i love my 4-runner and dont want to sell it PLEASE SOMEONE HELP ME thank you
Old 09-11-2008, 06:30 PM
Jory121's Avatar
do a tune up change, oil, plugs, wires, cap and rotor adjust the valves...thats what I did to mine seems to help
Old 09-11-2008, 08:20 PM
4Crawler's Avatar
22R or 22RE?
If a 22RE, fix the exhaust leak, assuming it is anywhere near the O2 sensor, guess what happens? Exhaust leaks out and air leaks in, air has O2 in it, sensor sees that and tells the ECU the engine is running lean so add more fuel. See if there are any stored trouble codes in the ECU:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
And some 22Rs have O2 sensors as well, not sure if an exhaust leak would have the same effect on them, though.
Old 09-11-2008, 08:27 PM
camo31_10.50's Avatar
where is the O2 sensor on a 22R..i got my cat cut off about..3 weeks ago..and had a turbo muffler and turndown put in its place..cuz ever since i filled up at a gas station about a week ago...i've been gettin bad gas mileage..and i've changed the fuel filter..and its due for an oil change..might as well do plugs and wires too...mine has poor acceleration too..but i am running 31x10.50 swampers..but i dont remember it being this slow on acceleration..im gettin better than 8 mile to the gallon..but i used to get somewhere around 20 on the highway..
Old 09-14-2008, 09:50 PM
kingbrian's Avatar
id try toput a cat back in it.. toyotas dont like to run so great with little back pressure. and the tune up as stated.
Old 09-14-2008, 11:49 PM
drew303's Avatar
02 sensor on a 22r is on the exhaust manifold. No idea what it does tho, It's only on the cali-models. Theres no ECU for it to feed info into, must be something else, even then the mixture cant be changed on a carb.
hmmm
poor gas mileage on a 22r? leaking fuel pump? sticking float? running rich?
Old 09-17-2008, 12:34 PM
Yote's Avatar
I have an '88 with the 22R. I keep mine very well maintained but at around 170,000 miles I started gettting around 15 mpg highway and it took me a while to figure out why. Everything was tuned up except I couldnt get the timing to hold perfectly steady when I put a light on it. It wasnt much but it danced around a little so I figured it had to be the timing chain since everything else I could think of was up to snuff. I took it to a shop and they quoted me $800 to do the work so I did it myself. Im no mechanic so it took me 3 days of mostly looking at it and rereading the manual over and over again but I got it done somehow. No leaks and it runs like a top and now has 208,000 miles on it. I recently had to give it to my oldest daughter because she needed a good vehicle. I just got a 97 4Runner and it has 150,000 on it and it feels like it needs a new timing belt on it to. So if youve got over a 100,000 mile on it, it could be the timing chain.
The only thing that makes me question that is that it sounds like yours started getting bad mpg after the exhaust work you had done. Its probably related to that but I would put a timing light on it anyways to see what it looks like. It quick and easy and doesnt cost anything.
Old 10-24-2008, 08:08 AM
talon_5150's Avatar
hmm my 84 toyota truck gets 17 i thought that was bad
Old 10-24-2008, 08:15 AM
1styota4X4's Avatar
what was the original tire size on the truck did you just go to bigger tires? That can play a part in the numers as well.
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: my very sick 22-r eats fuel like i own a gas station
