leaky cv axel
leaky cv axel
"as long as you don't do it every day and you clean up under it when your done it will be fine.... unless you got a broke axle boot.....then the water will get in there and have a hay day! "
I asked if Ishould worry about water and this is what I got in response. well, my cv axel is leaking, but the mechanic asid I have awhile until it goes. How long do you think? If I get one replaced, should I replace both? is there a btter cv axel than stock? how much should it all cost, and could I do it myself?
TheBFA
02-15-2020 06:55 AM
