leaky cv axel
"as long as you don't do it every day and you clean up under it when your done it will be fine.... unless you got a broke axle boot.....then the water will get in there and have a hay day! "
I asked if Ishould worry about water and this is what I got in response. well, my cv axel is leaking, but the mechanic asid I have awhile until it goes. How long do you think? If I get one replaced, should I replace both? is there a btter cv axel than stock? how much should it all cost, and could I do it myself? |
you do know you could have asked this on the post where you pulled the quote from
