Engine wont fire? - 1993 4Runner
Old 03-04-2011, 12:32 PM
Webster93's Avatar
My 4runner wont fire but it is turning over, what could cause this to happen?... I was in a store parking lot driving to the exit then my car stalled out ( i bought my 4Runner used and it has always done this on occasion, but always started right back up ) when i tried to start it again it would turn over but not fire???
Old 03-04-2011, 12:38 PM
83's Avatar
Ignition module, coil, distributer...on the electrical side. Also plugs wires & rotor. Could just be you need a tuneup...
Fuel pump, injectors...on the fuel side.
You're probably getting compression.
Make sure you're getting spark and fuel.
Old 03-08-2011, 03:06 PM
odysseyvip's Avatar
Engine won't start
I need help. I had my oil changed in my 2002 V6 4Runner and while heading home my truck shut off. I checked my fuel pump and it's pumping properly. I was told it could be the crankshaft sensor which I purchased and replaced but still nothing. After installing the sensor it turned on but shut off quickly.
Old 03-10-2011, 06:20 AM
83's Avatar
Start your own thread.
Weidle
01-21-2019 05:39 AM
Colington
10-12-2015 05:41 PM
Valvoman
06-28-2015 02:45 PM
odonekanobe
06-26-2015 02:27 PM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: Engine wont fire? - 1993 4Runner
