do you have to remove head to change valve springs
Old 11-05-2010, 06:09 AM
  #41
Shifty762's Avatar
I know the timing on my 1987 22R (carbureted) is to be set at 0*... rpm not exceed 950rpm. Make sure vacuum advance lines are unplugged from your distributor and the lines themselves are capped. This should be printed under your hood.
Old 11-05-2010, 06:19 AM
  #42
xxxtreme22r's Avatar
his is efi. 15 degrees though seems kinda high, I think it's supposed to be 5 BTDC with the jumper in place.
Old 11-08-2010, 02:09 PM
  #43
808nickh's Avatar
yea im gonna retard it a little my next day off, i have to dig back in there because it looks like my oil pump is leaking a little i might of pinched that rubber seal when i put it on does anyone know the torque spec. for the oil pump by any chance?
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
Nickdigg
07-07-2015 06:04 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: do you have to remove head to change valve springs
