diff gears will they fit?
well im trading my stock gears with a man who has the 5.29s...we are swaping out the whole 3rd members i have a 92 and his is i believe a 95....how do i know for sure they will work like what do i have to match up?
If the gears are already setup in a housing and you guys are swapping whole thirds, then you will be fine.
Click link in my sig.
I would at least check the gear mesh pattern before throwing them in your rig, If they were not set up properly it won't last long.
yep drop em in i run 5.29's with no clearance issues. and as stated above look at the contact pattern if it is crappy i would pass if they were ran a while that way
no same size just a different carrier is all. most toy thirds are interchangeable even the elocker with a slight mod. the only one that wont fit is the bigger land cruiser diffs 9inchers i think and the new taco 8.4. a plain third with a locker and 5.29's will fit in there and you are getting a bargain if he is trading you straight up
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
scottyg486
07-19-2015 05:34 PM
